Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Fan is Louder than usual
My TV's fan sounds like it is working in overdrive. It is very loud and constant. This TV has never been worked on by myself or any tech so I am certain that this was not done through poor repair or self repair.
  • jorgewally_ Dec 06, 2008
    my tv works fine for like 20 min or some times not even that bero it starts to make a really loud noice it sounds like the fan started to run harder or if there was something stock in there.
    what can i do to fix it?
    Sergeant:
  • 350 Answers
Your best bet is to unplug the tv give ten mins to allow the capacitors to discharge get a flat table with a sheet on it lay the tv face down remove the screws which hold the back cover on locate the fan look at it carfully to see first of all it is seated in its housing or the fans housing is screwed or clipped in its holder properly if everthing is as it should be remove the wires off the the fans connector remove the fan revolve the fan see if it makes any noise at all then see if there is any play in the fans bearing buy rocking the fan back and forth see if there is any signs of where the fan is catching the side of the fans housing if your not sure leave the fan out place the back of your tv back with a few screws plug it back in turn your tv back on see if the noise goes if not its not your fan the fan is acooling device so don,t leave it out any lenth of time otherwise the tv,s ciciuts will overheat yates210456
Posted on Sep 26, 2008
Remove fan motor
Have more children (I cant even hear myself think)
>> design problem, not going to fix it with new parts..... ear plugs?
Oct 16, 2013 | Belling Ovens
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Sony kdf50e2000 fan very loud. tech already replaced and now says one of the ''other'' fans has gone bad. how do i find and replace/buy the fans myself?
just go a repair shop sony buy the fans /open the tv set back panel before doing that you have to put the tv on the a table with something under to protect the face plate of the tv, then remove the back panel and replace the fan shes screwed on a metal parts of the frame you will find a connector for the wire of the fan
then put the panel back screwed and your done
use care!
hope that will help you,have a nice thay....
Mar 13, 2010 | Sony KDF-50E2000 50" HDTV
Vizio L42 - sound set to 0 and still loud distorted sound
I unplugged the TV and let it sit for about an hour and now appears to be working as before. Still strange, have never experience this before. I could understand no volume.
Sep 03, 2009 | Vizio L42HDTV 42 in. LCD Television
No screen or sound
there are only two moving parts in your tv a fan and color wheel, that noise is classic of a color wheel, I had the same tv and problem. I replaced it myself but it is a little tricky. part is around $175.
Mar 06, 2009 | Samsung HLP5067W Television
The fan in the tv is too loud.
Thiscan happen for two min reasons.
1. Dust
2. Fan's bearing gone bad.
Easiest way is get a compressed air can and clean the fan. (You do not need to take the TV apart)
If it did not work, replace the fan. (Will not cost you more than $20)
Feb 20, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Loud Fan
Yes, fans are somewhat the bane of these new TV technologies. With all the mechanical and optical stuf in them now, TV's are a lot less reliable than the good-ole CRT type.
Fans are easy to replace though.
Jan 03, 2008 | Panasonic TH-42PHD8UK 42 in. Plasma...
Samsung HLP5063WX -- 50 inch DLP
I have the same problem. I called Samsung and talked to a tech who thinks it could be the barrings in the "color wheel" are going out and making the noise. He didn't think it was the fan because that doesn't turn on until the tv warms up. After a 30 minute discussion he felt certain that was my problem. I haven't had it repaired yet so I can't be sure. Hope this helps.
P.S. I don't have any problems with the color.
Dec 20, 2007 | Samsung HCM4215W 42" Rear Projection...
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
126 people viewed this question
Henry  Thomas
Henry Thomas
