Question about Fuji FinePix Z10fd Digital Camera
Dark Spot Appears in Photos
I got this camera at Christmas of 2007 after my A350 died. Love the camera and I got the 2 year warranty this time. :-) The only thing that is going wrong with the camera is that sometimes when I take photos, there will be a dark 'blur' on the lower right of the photo. It is there when I am shooting in macro mode and normal mode. Sometimes when I zoom in and then back out, it disappears, sometimes it doesn't.
It appears both on the LCD screen and in the photos. It's enough to just bug me. Most of the time I can crop it out of the photos, but this is a (fairly) new, expensive camera. I've cleaned the lens with a micro fiber cloth and an alcohol prep pad. I've left the battery go dead and charged it.
It is almost like a piece of dust somehow got in under the lens or something. Help!
  • Fuji Master
  • 16,852 Answers
This could be from a couple of things. One is a picture that was taken in bright sunlight that burned the image cell. The other also is an image cell issue not related to sun exposure, Precision Camera Digital Camera Repair Video Camera Repair is a place that I recommend.
Posted on Mar 17, 2017
A dark spot appears on the photos. The camera is
Chances are you have dust on the sensor.
Its unlikely that you will be able to clean this sensor on this camera manually.
However you could try using a simple rocket blower via the battery compartment, this may move the suspected dust particle.
To clean this sensor manually would be a risky job if not a camera technician.
Hope this helps
Dec 16, 2009 | Canon PowerShot A520 Digital Camera
My Nikon N65 flash leaves a dark spot on all my photos
I love that camera. There are several possiblities, If you are using the pop up built-in flash with a telephoto lens or a lens hood you'll get a shadow in your photos ususally at the bottom of landscape oriented shots. If you are using a flash unit attached it may have something interfering with the strobe possibly or it is turned. We have the same camera and have had the shadow issue in the past. The pop up just won't work if something is wrong with the "bulb" the only other thing is that is isn't going all the way up, check that also.
Jan 13, 2009 | Nikon N65 35mm SLR Camera
Dark pictures
There are several possibilities.
1) The camera store screwed up, and your photos are just fine. Have you looked at the photo files on your computer?
2) You accidentally set the camera into manual mode and with settings that don't work for the light. How do the photos look when you preview them on the camera?
3) This is the most likely problem: It sounds like you have accidentally set the "exposure compensation" value. This setting is used to help correct the exposure when shooting a scene that should be mostly white (e.g. in the snow, or bright sand at the beach) because otherwise the camera will make the scene be "medium gray". Check your user manual for instructions on how to set the exposure compensation and make sure it is set to 0.
If your photos are too dark when viewed on the computer and the preview screen, and EV is set to 0, then your camera may have a faulty light meter. If so, you need to send it in for repair under the warranty, or return it to the place of purchase as defective and see if they will exchange it for you.
Dec 31, 2008 | Nikon Coolpix S1 Digital Camera
Panasonic lumix dmc-fx01
If the dark spot is not focused, it could be on the sensor. Otherwise, check the lens for any dust particles. If you can't find any dust, take the camera to an authorized service center.
Aug 20, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Olympus FE-280
1 year warranty on olympus products, but does not cover physical damage such as impact, water, or sand
Jul 18, 2008 | Olympus FE-280 Digital Camera
Blurry Spot
First check lens for any moisture when the cover is open - even dried liquid.
If it is consistent, and you've cleaned the lens, then the CCD may have a fault on it.
This would need returning under warranty if it is still covered.
Jun 26, 2008 | Fuji FinePix A350 Digital Camera
Dark spot appears on all photos
check the shutters, it prob not opened all the way
Dec 17, 2007 | Canon PowerShot A530 Digital Camera
Taking night photos with the A350
I suggest you find a tripod and use "No Flash" as the reason the pictures are blurry is usually the camera moved. I love the no flash option, but since the shutter stays open so much longer, a tripod is almost a necessity.
Dec 16, 2007 | Fuji FinePix A350 Digital Camera
LCD White-out
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
Sep 07, 2007 | Fuji FinePix A350 Digital Camera
I have had a similar problem. Pictureres look like they are taken through a Venetial blind with white horizontal bands though I did get one with dark banding. It appears to have something to do with light levels. I took a few pics in a dark area with no flash and now it is working again...until it quits working again. Perhaps it is something to do with light level calibration? Whatever it is the problem is internal. If you are still under warranty, I highly recommend taking your camera in for repairs/replacement. Ours started acting up just after the warranty expired so no love for us.
Aug 07, 2007 | Kodak EasyShare C533 Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
44 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
