Question about Motorola Mobility RAZR V3
Blue tooth not working
Will not pick up other devices
  • 67 Answers
Have you tryed a master reset on your handset, this usually cures 95% of handset issues, if not ring your network operator for assistance.
Posted on Sep 26, 2008
My computer is not picking up the head set. I've tried to do it manually also.I have a gateway touchscreen with windows 7. can u help please?
You must put your blue tooth device into discovery mode ,most manufactures use the power button for this feature ,,by holding it for 6 to 10 seconds when turning on your blue tooth device,thenwhen searching they will pair,you will have to enter a pairing code .Most blue tooth manufactures use a 4 digit pin or pairing code they are as follows 0000,1234,9999 or 1111 i hope this helps
Feb 20, 2011 | Dynex Mono USB Headset with...
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
My samsung bluetooth won't work with my tmobile mytouch slide
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 20, 2010 | Cell Phones
My Droid won't pick up the Jabra VBT3050
Take note that it's all blue tooth device that is universal,so might not work with our phone. You will need to try it on another phone to be sure if the blue tooth is OK.
Aug 06, 2010 | Cell Phones
Bluetooth not working in sony W580i phone
HOW TOCONNECT BLUETOOTH
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
On my ps3 bluetooth scanning for a ps3 headset its
Make sure that your blue tooth is in pairing mode when the sysytem is scanning.(refer to blue tooth headset manual for intrustions)
I hope i have helped and I hope it works!!
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Samsung SGH-D820 bluetooth static problem
find somebody else with blue tooth on their phone or get a device that is blue tooth ie hands free kit then on your phone select search for bluetooth devices if it finds any then select the item you want ie a friends phone or blue tooth if it says it is active then your blue tooth is working but to use the item with bluetooth you have to select the item it should come up as a list of items select the one you want then this should pick it up and this should solve your problem if not post back and i will try again hope this is some help.........................
Nov 01, 2007 | Samsung SGH-D820 Cellular Phone
MY BLUE TOOTH ISN'T BEING READ BY MY PHONE...
Delete the headset from your phones previous or known devices and turn off phone then back on again and try pairing again. If still same could be faulty phone, but if you can try headset on somebody elses phone to rule out headset.
Jan 23, 2007 | Audiovox SMT5600 Smartphone
Motorola Mobility RAZR V3 Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
