Question about M-Audio Fast Track USB (FASTTRACK) Audio Input
M-Audio Quattro USB Interface
I have the same problem, I upgraded to Vista from XP and need help getting my audio interface working....M-Audio Quattro USB Audio Interface...
Release Date: December 12, 2003
Applies to:
Quattro USB
Operating System(s):
Windows 2000, Windows 98 SE, Windows ME, Windows XP
Thanks in advance...Jay
  • sfavela Dec 22, 2008
    Did you get a solution for that problem? The same is happening to me.
I have a US 122 USB audio midi interface wich worked fine with windows 2000 now I have windows 7 and how can I make it work
Try the driver for Vista (including x64) from . It's version 3.40. You may need to use the compatibility mode. Right click on the installer after you extract the contents of the .zip file. Then choose Properties and select the Compatibility tab. Check the box for Run this program in the compatibility mode and select an older OS version. Then click Apply and OK. Then right click again and choose Run as Administrator.
The other options is to use the Tascam US-122 with a computer with an older OS or upgrade to a Win7 compatible model. If you try an older version of Windows, you can use a second computer, a dual boot machine or a virtual computer. If you have Win7 Pro or Ultimate or upgrade to one of them, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
Jul 02, 2011 | Tascam US-122 USB Audio/MIDI Interface...
Son wants to buy CAD GXL2200sp studio microphone package and wants to plug into laptop.Will that work?
for purposes of recording quality, I would recomend getting and external sound card. M-audio make a good range. You would need to have a +48v phantom power supply for this unit to work. The sound card you buy should have this. A Pc or laptop won't
Jan 16, 2011 | CAD Microphones GXL2200 Professional...
Mobilepre usb and windows vista are non-compatible
There should be a Vista driver available for your device at the M-Audio support website.
Post your results back here.
Mar 31, 2009 | M-Audio Mobilepre USB Bus-Powered Preamp...
Recording Device
Pcs needs drivers, and vista is far from being completely stable..
Disconnect the mobile pre...and go here:
then restart and connect.
Rock those beats, and keep me posted.
Dec 11, 2007 | M-Audio Mobilepre USB Bus-Powered Preamp...
Sound not working after upgraded to vista with a LG LW70 Express
ok. I can help u if u say specifically what is your sound card full name and the version or the driver... anything about the sound card...and then i will search the good driver 4 u.Bye Bye...
Nov 27, 2007 | Computers & Internet
M-Audio Fast Track USB (FASTTRACK) Audio Input Logo
90 people viewed this question
Top M-Audio Televison & Video Experts
Paul Bade
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
