Question about Kenmore 62602 Electric Dryer
Dryer My dryer is doing the same thing. What did you find the problem to be?
  • 943 Answers
Thanks for the question. check the blower . if that fails no blowing of air to the outside whlce can cause the element to over heat, and longer to dry the clothes. clean all venting thanks the appliance doc please rate my answer .thanks
Posted on Oct 09, 2008
How to remove front from frigidaire dryer
1)The first thing you need to do is unplug the dryer.
2) You will need to pop the top of the dryer. This can be done with a flat screwdriver. Place the driver between the top and the front of the dryer and basically just pry upwards.
3)Now, that you can see inside the dryer, the next thing is to remove the front of the machine. At the upper left and right sides you will find a screw that holds the front to the frame of the dryer.Remove these screws and you can take the front off.
May 27, 2012 | Frigidaire Electric Dryer
My dryer keeps shutting off every 10 to 15 minutes. I have changed the motor and it still does the same thing. The elements are good cause they have continuity thru them. I need help to get this problem...
It's difficult to say because there is missing info, but, the first thing I would look for in a dryer would be a clog on the exhaust to the outside of the house that might make the dryer overheat. There is probably a safety circuit breaker or overload that "trips" when the dryer overheats. It could also be that there is something stuck on the outside of the dryer drum that may be causing it to have higher friction than usual and possibly slowing down the motor.
Apr 23, 2011 | Dryers
Every thing working but no heat .how do i repair this
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 11, 2011 | Tricity Bendix TM310W Electric Dryer
How do i light the ignighter on my dryer is spins but dont heat
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 16, 2010 | GE Profile DPSB613G Gas Dryer
HOW DO I LIGHT THE PILOT LIGHT
heatman101
Aug 15, 2010 | Estate TGDS740JQ Gas Dryer
DVL223GB Dryer got hotter than normal do i need a new thermel switch
Probably nothing more than a good cleaning is all it needs.
Some repair photos: HERE
Jan 02, 2010 | GE DVL223GB Gas Dryer
Frigidaire clothes dryer struck by lightning
First thing you need to do is determine that it is the dryer. we had a similar problem and it turned out to be the connections in the dryer plug. you should have 2 prongs in the plug with 120volts and one hole with no voltage.
Sep 23, 2009 | GE Profile Harmony DPGT750EC Electric...
Wiring wiring the dryer plug on a hotpoint dryer
First thing do you have a 3 or 4 prone cord?
For 3 prong, when looking at block where cord attaches you have a left, center, and right screws, attach just like cord 3 wires, left on left, center on center, right on right. The only thing different with a 4 prone is you have a ground wire which grounds to ground screw on dryer.
Aug 20, 2009 | Hotpoint Ariston NWXR483EGWW Electric...
Dryer will spin but won't heat up
Hi
Things that could stop a electric dryer from heating:
  • house fuse or breaker ( needs two of them )
  • heating element, burnt wire
  • thermostat(s), thermal fuse ( not all models ),
  • motor heat switch, timer, selector switch,
  • burnt power cord/plug.
You can check these things using an ohmmeter/multimeter from here.
Things that could stop a gas dryer from heating:
  • glow bar igniter,
  • thermal fuse ( not all models ),
  • coils on the gas valve, gas valve, thermostats,
  • motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Whirlpool Dryers
Not heating
Hi
  • glow bar igniter,
Thanks
Rylee
May 20, 2009 | Kenmore 62802 Electric Dryer
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
