Question about Compaq Computers & Internet
No sound. Computer tells me that sound devices are operatating but won't let me change volume or any other sound settings.Compaq sr2010nx.
  • David Allee
    David Allee May 11, 2010
    Could you be a little more specific? What OS are you using and where did you see these messages? Did you go to Sounds and Audio Devices (or the Vista equivalent)?
    Scholar:
  • 191 Answers
Reinstalling the audio drivers may fix the problem...
Posted on Sep 27, 2008
Installed lynex on my compaq presario sr2010nx and i cant get the sound to work
Make sure the audio drivers are in the device manager. Make sure the volume is turned up and not muted. Look at the Audio/Sound properties in the Control Panel and make sure they are not muted and the volume is up. Make sure you have the speakers plugged into the light green port on the computer and that the speakers are on and the volume is turned up.
Apr 11, 2012 | HP Compaq Presario SR2010NX PC Desktop
My compaq presario c300 doesn't have sound,so l need your assisrance
i will be very broad with your sound problem it could be a number of things
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 22, 2011 | Compaq Creative Sound Blaster PCI 128...
I have laptop Compaq nx 8220 , the internal speaker of my system is not working however the sound through headphone is perfect !
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 10, 2011 | HP Compaq Computer Speakers
Sound device not found in C 700 compaq
the sound drivers might not have been installed for the sound card
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers :
also
Jul 08, 2011 | Compaq Audio card Sound Card
My compaq presario sr2010nx desktop won't turn on. I tried fooling with the off/on switch wiring and it came on for a short time. All was well. I hadn't used it for a week and tried to turn it...
Hi.
Sounds more like a power supply problem. First test the on/off switch by tracing the wires to where it connects to the mother board. The plug is usually marked "pwr sw" . Unplug the wire from the board & short out the 2 pins where the switch was plugged in using a small screw driver or any other conductive material. If the pc still fails to turn on, try replacing the power supply.
Best wishes,
Graemevm
May 10, 2011 | HP Compaq Presario SR2010NX PC Desktop
Am using hp compaq desktop , my pc sound is not wrking,wat solution?``
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 30, 2011 | Compaq Computers & Internet
Sound Monitor Compaq FP 7317
You need the proper driver for your monitor, and you will find it here: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&product=324199&dlc=en&lang=en
If you require instruction on how to update the driver, let us know?
Good luck.
Mar 21, 2008 | Computers & Internet
Replacing video card
hmmm..old card should just remove with one screw along back panel, unless it's the embedded version
go to control panel, system, device manager, and let me know what it says under audio devices.
Feb 25, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Computers & Internet Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
