Question about Pioneer AVIC-N2 Car DVD Player
Pioneer bypass got avic-n2 back from pioneer with solder points grinded down. whats the next solution.
  • Anonymous Nov 03, 2008
    i have pioneer avic but i cant watch videos while driving
Can you please help me bypass my pioneer avic n2 please i want to watch video while driving
Posted on Nov 03, 2008
  • manfred_boat Nov 03, 2008
    can you please help me
How do bypass it and i want to watch video while driving please help me
Posted on Oct 30, 2008
YES I DO
Posted on Oct 27, 2008
My pioneer avic n2 will not turn on,but when the
sounds like you have blown your acc fuse or your risistor on your red wire on your radio has shorted out you can bypass this wire by choping it off it dose not affect the radio ,dvd at all.
Jan 17, 2010 | Pioneer AVIC-N2 Car DVD Player
Avic bypass
The original Avic N1 only needed to have the parking brake wire grounded for video in motion. Then, the latter series came out and on the underside of the in-dash unit, they have a foil sticker that needed to be removed and a jumper carefully soldered on the circuit board. Avic N2's had a switch installed under this sticker to avoid people from making soldering mistakes. I think the N2 brain may be looking for an N2 unit and giving you trouble. more info on this subject is available @ www.avic411.com.
Aug 04, 2008 | Pioneer AVIC-N1 Car DVD Player
Avic-n1 bypass
Heres a good site that has alot of bypass guides for Pioneer Avic Units
http://underground-secret.com/avic_n1_bypass.html
Pioneer Avic D1, D2, D3, N1, N2, N3, N4, Z1, Z2, Z3, F700BT, F900BT & F90BT.
Aug 03, 2008 | Pioneer AVIC-N1 Car DVD Player
Avic N2 Issue
You can still perform the bypass internally. The N2 is done by connect the two points under the VOID sticker and the N1 will have to be taken apart completely. Unless you are a pro, I would recommend that you have it done professionally. Sound like someone tried and put too much solder and then cleaned up but also took out the pin. If you need I can perfome the bypass or if you have enough guts I can walk you through it. The instruction is sellling on Ebay for about $10. Unless you are really technically incline it very easy to fry your unit beyond repairable. Goodluck.
Jun 12, 2008 | Pioneer AVIC-N2 Car DVD Player
Bypass for N2
there are to steps, very simple...
solder two points under the silver sticker on the bottom of the head unit (pay a pro! don't mess up your deck!) then you ground the light green parking brake wire (attach it to the black ground wire coming out if the same harness) this will give you "full function". i have this unit and have the upgrade, it works.
May 08, 2008 | Pioneer AVIC-N2 Car DVD Player
AVIC N2 parking brake bypass
There are two ways to complete this project:
1st
underneath the mounting bracket of the radio not the brain theres a silver sticker like mentioned above there are two silver solder points right beneath the sticker it must be jumped with a wire or you can use the solder to connect the two contact points after this you must still ground the green parking brake wire to the car.
2nd-(also my favorite choice and the one I'm using on my N5 & on my 7800dvd those who know pioneer know what i'm talking about)
buy a ptr7 pheriphial device and wire as follows (they come factory ready to bypass alpine and pioneer units)
wire as follows-white wire to green parking break of the deck your bypassing
red wire to vehicles 12v source
green wire from device to remote
black wire to vehicle ground wire
final important step I know because this happended to me
make sure you take a little screwdriver agfter wiring or something and switch the
PTR 7 to the off position-or else this will make the PTR7 not function correctly
How do i bypass the parking brake switch in order for my video to play
N1 internal solder bypass to work with newer software, N2 solder the two connection under the silver sticker(might void warranty), N3 switch the switch under the silver sticker(might void warranty). Goodluck.
Mar 31, 2008 | Pioneer AVIC-N2 Car DVD Player
Avic n2
You have to bypass the Parking Safety feature. Here is the info I have found. I have not verified it myself for accuracy, so use at your own risk. AVIC-N2 lockout bypass: Underneath the MAIN unit (not the hideaway) is a small silver sticker, peel this back. There are two contacts with the label "R197". Drop a bit of solder between these to connect them. Also, you must ground the Parking Brake wire.
Sep 26, 2007 | Pioneer AVIC-N2 Car DVD Player
Pioneer avic n1 video by pass but now doesnt work when i upgraded w n3 disc
I am pretty sure that pioneer does this so you cant bypass it. The n1, you just have to ground the parking brake wire,the n2 you have to solder the 2 points together under the piece of tape, the n3 you have to move over the switch on the side of the unit. Which all of these void your warranty anyway but I think that is why people eventually downgrade the the old dvds.
Feb 05, 2007 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
Pioneer AVIC-N2 Car DVD Player Logo
298 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
