Question about Gateway FPD1975W 19" LCD Monitor
LCD MONITOR MY MONITOR IS ON, BUT NOTHING SHOWS UP ON THE SCREEN.
  • 97 Answers
Diagnose the problem first:
- If you have CRT Monitor try to connect to your Computer.
Posted on Sep 27, 2008
  • Gateway Master
  • 5,568 Answers
If you have a power LED on, I don't think the power cords are at fault. Check the screen at an angle when you expect video to be present (PC on) to see if you can espy any video that might be there. It sounds like the backlight or its power supply (inverter) has failed. Without it, the video can be present but not visible except for some dim traces when lit by ambient lighting.
Posted on Sep 26, 2008
  • 42 Answers
Check the power chords
No display upon turn on
Did you press and hold the FN function key plus the key that toggles the display? In your case it might be the FN+F8 if F8 is the key that toggles the display.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If your video card is bad you will not see anything on the laptop's lcd screen or the external monitor.
Jun 10, 2012 | ASUS Eee PC 1005HAG Notebook
I have a XPS M1530 the screen is black I press the power button for a second it stay on everything lights up sounds and feels like its on gets warm but nothing on the screen Itrying everything taking out...
You either have a Video Card problem or an issue with your LCD Screen.
Does it every post anything to the screen? If nothing ever posts on the screen when you hit the power button and it will not do anything with an external monitor, then your Video Card is bad. I wonder if you have the Nvidia Graphics Video card on your system?
If it seems like the laptop booted up all the way (you hear fans running, hard drive spinning, see lights) but the screen is black then try the steps below.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 16, 2012 | Dell Computers & Internet
Hp Pavilion DV-4000 Screen
Are you saying the lcd screen is black? It seems like it booted up but nothing appears on the screen?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 03, 2012 | HP Pavilion dv4000 Notebook
Monitor turns on and computer runs monitor is plain
look like ur RAM is crrupted...if u can see some alpha numeric char while starting then screen is OK
or Windows may be corrupt...
May 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Dell B130 laptop boots up and you can hear all the boot up sounds, however nothing shows on the monitor. It's completley black.
connect to a desktop monitor if u see the screen
change the output screen (tv,lcd) then unplug the monitor if the problem not solved
there is a problem on lcd ,lcd cable or vga adapter
Aug 09, 2009 | Computers & Internet
No Power LED and Nothing on the screen
Check your power supply to your screen cause it should at least show a amber light at the screen to show that there is power but no proper signal from the computer.
So below are step to check the power supply to your monitor. Assuming if you use a different monitor on your pc it works
1. Check your fuse both internal and external
2. check if power is receipted by the LCD
Mar 24, 2008 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Gateway FPD1975W 19" LCD Monitor Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
