Question about Dell Inspiron 1000 Notebook
No windows or system screens black with looping text
I was taking my laptop apart and the screen went blank my lcd screen quit functioning i connected a new monitor and now windows is gone and i have no screen options anything i can manually do or what are my options and costs to fix this
  • 158 Answers
I think its a display problem its giving a continuous beep if yes then you have to repair or replace your display from near dell service centre
Posted on Sep 26, 2008
Compaq presario v6000. no problems when closing next time I oppened it I got some horrizontal lines on the screen then it went black and now can get nothing. All the lights are working but cant get any...
There is a hardware problem with the laptop that is why the screen is black. Take a good look at the screen with light reflected on it, to see if it looks in any way damaged or have some kind of ink on the screen, if you do not see any of the two, then it simply means the module of the laptop is faulty.
The module acts like a flex on the laptop, if the laptoo hits a hard object or falls or have a heavey load placed on it, then, the module can develop some fault.
First, it starts to flicker, then it shows some horizontal lines, then it goes blank once in a while, sometimes it remains stable, and later on, the screen does not come on at all while other parts remain functional.
Try to have a repairman replace the module of the laptop and it will be in good condition once again.
For the main time, you can use a external monitor or a lcd television. To use this, check your lcd television if it has the RGB(PC) port at the back, then you get the cable that connects a CPU to the monitor, and connect it into the printer port on the laptop and connect to the RGB(PC) on the lcd television.
After connecting, your television will serve as the screen. And you will enjoy your laptop from the lcd.
Take care and good luck.
Oct 25, 2010 | HP Computers & Internet
Hp pavilion dv6810us -- the screen went blank suddenly (no hint of a problem) and can't get it back to normal. I've forced shut off and turned back on (4 times over two days)...still black screen. All...
if it was the video card ...it will appear something on screen like Bios...when accessed..and affect only the installation ...I suspect the lcd connection
so...assuming is nothing inside...take a look on this tutorial
http://www.laptop-repair.info/laptop_screen_repair.html
Nov 09, 2009 | HP Pavilion dv6810US Notebook
Sir, I've a lenovo 3000Y500 series laptop for the past 2 yrs. Yesterday, while browsing my LCD just went blank. on restarting, the screen went redish and turned blue(normal)logon screen and went black...
the LCD backlight is not functioning. It could be a high-voltage inverter failure. Have it checked by a competent technician or service center.
Aug 26, 2009 | Computers & Internet
HP Pavilion laptop screen has gone black/blank
You can either use an external monitor for working with the laptop or talk to HP for replacement.
The best option is to use external monitor to backup data before sending it to replacement.
Good luck
Jun 22, 2009 | HP Pavilion dv6835nr Notebook
HP Compaq NC6220 won't boot
I'm running into the exact same issue. Were you able to resolve the situation?
Fatima
May 16, 2009 | HP Compaq nc6220 Notebook
Trouble starting up laptop
Most portable computers have a monitor loop-through or simultaneous viewing function. Press the FN +F4 function keys on the portable computer to switch the image from the portable screen to the projection screen or to toggle through the following three options:
  1. Liquid Crystal Display (LCD): Output displays only on the portable screen.
  2. Cathode Ray Tube (CRT): Output displays only on the projection screen.
  3. CRT/LCD: Output displays on the portable screen and the projection screen.
Oct 26, 2008 | Computers & Internet
My dell inspiron 1000
Can you see the Dell splash screen after turning it on at least? Check first your hard drive by doing diagnostics. Hit F12 for the diagnostics options to test its functionality. If everything passes, then there is still a way to recover the files. Are there any files on your computer that needs to be backed up? You need to consider this before doing the restoration options.
Sep 26, 2008 | Dell Inspiron 1000 Notebook
Blank LCD screen
you have accidentally turned the lcd pannel button off.just turn it on.
Feb 03, 2008 | Canon PowerShot A630 Digital Camera
Freezing then blank screen
you have a loose connection, good luck....
Jan 08, 2008 | Samsung X15 Notebook
Dell Inspiron 1000 Notebook Logo
48 people viewed this question
Alun Cox
