Im already connect to broadband and now i am trying to add a wireless router. someone sorted it out on my last laptop but now i need to sort it out on my new laptop. please help
Right click on the tv symbol along the bottom of the screen, view available wireless networks and your desktop should be listed, giving you the option to connect, unless you have put security onto the network, in that case you should know the password.
Posted on Sep 26, 2008
I have a mfc-j410 and am trying to go wireless with an EVDO u210 usb mobile broadband on my laptop. Can not get it to connect wireless. Any suggestion would be appreciated
What you are proposing cannot be done as a mobile broadband modem is sort of a 'mobile phone' device (e.g. Dual band for CDMA 2000 1X and EVDO Rev.A networks 800/1900MHz) and your printer would at best be WIFI 802.11 compatible (ps. MFC-J410 has no 'W'ifi support).
Brother MFC-J410 is USB connection can only be used to connect to a PC/Laptop or print server/router (which may have WIFI support).
Sep 18, 2011 | Office Equipment & Supplies
Toshiba satellite 3000 will not connect to wireless router
Have you checked to see if your wifi is turned on by pressing Fn+F2 this turns on or off wireless on the laptops if it is turned on have you tryed the install cd that comes with your router most routers have an setup cd surpled with them if that cant sort it try to update the wirelass driver for your laptop if that dont fix it then its the manual way via the broadband tec team on the phone so that they can give you the right settings for it other than that get a better laptop that is surrported by your broadband surrplyer
Mar 25, 2011 | Computers & Internet
I"m tryingo to connect my
I suspect that you have setup your router to expect a password of sorts and your lap top is not sensing the auto find feature. Check:  http://www.retrevo.com/support/Linksys-WRT54GS-Wireless-Routers-manual/id/421ci076/t/2/  for a primer on how to setup the WRT54G router.
Nov 27, 2010 | Linksys Wireless-G Broadband Router
Need to enable security -- had a power failure -- the computer with direct cable connection has internet access, but my laptop with a wireless connection no longer works -- says the network "is unsecured...
Log in to the router, check Wireless settings, Security is in the same area. I find that WPA-PSK[TKIP] is the easiest type to use, as you can use pretty much any sort of password longer than 7 characters. This can be done with the wired connection.
Nov 09, 2009 | Linksys Wireless-G Broadband Router
Getting laptop connected to web-not Int. Explorer 8 issue
In order to get her connected legally, you will have to set up your own wireless network. This will require a broadband connection of some sort (DSL or Cable modem) and a wireless router. Your ISP or the routers tech support should be able to help you with basic configuration.
Jun 03, 2009 | HP Pavilion zx5000 Notebook
Laptop connecting but not my desktop
> Try changing and creating a new wireless network name.
> Try changing your security mode like WEP to WPA or vice versa..
> Try to update you drivers on your laptop then restart your computer before connecting to your network..
> Try assinging DNS ( Domain Name Server.) ask your router manufacture for the DNS that you could use.
> Make sure you typing the correct password for your wireless network..
> Make sure you disable WI-FI protected setup and on the router.
> Try to disable Anti-virus and Firewalls on you laptop.
Feb 17, 2009 | Linksys Wireless-G Broadband Router
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
Sep 03, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
I have a wireless g broadband router i am connected on the main computer but my wireless computer says connected but i cant go to any web pages
Is the problem that "nothing coming from the modem to the router"
if the router has more than one Lan port try the cable from the modem to the router, in the first lan port or the last port.
if its a wireless problem,ensure wireless router function is turned on ,and the adapter is enabled on the pc ,
if you set up a security key in the router ensure that it is put into the other pc wireless setting.(but try setting up without any security keys) when succesfull you can ad the security measures.
sometimes you need to turn on the modem first then turn the router on after a little while to sort the ip address out before trying to connect the other pc, in the first instance.
hope this is of help
please rate my efforts as this is our reward
good luck
Terry
Apr 04, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
