Question about Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive
Flashing green power light
When I plug the power cord into my external hard drive, the power button flashes green rather than staying lit up the whole time. It doesn't seem to be getting enough power to get the hard drive working. My computer doesn't recognize the connection at all.
  • markbarrett Oct 11, 2008
    I have the same problem
  • Anonymous Oct 15, 2008
    I regularlly use my Maxtor external hard drive until it's started flashing this green light when the power cord is attached... Can anyone help?
Spoke to maxtor. The blinking green light on the power cord is a problem with the external casing for the hard drive. Several of the posts talked about taking the case apart and connecting it to the pc to download information. I thought they were crackpots. After talking to the service tech on the website it looks like that is the only fix. So... based on all the posts with the same issue I may avoid this product line int he future. Hopefully it is truely a backup for you in which case toss the old one and buy a new ext. HD. If it isn't a backup take it apart gingerly, download the information, replace the hardrive.
Posted on Dec 19, 2009
I'm not 100% sure it's the issue, but it sounds like you shorted the board. I just had this problem because I accidentally plugged an identical looking power supply from another drive into my Seagate. But the voltage on the two power supplies were wired differently and they'll both plug into to the same jack. Why they do this I have no clue, it's confusing, damaging and possibly dangerous.
Anyway, I took one of my other drives out of its casing, unhooked it from the IDE (40 pin) and Molex (4 pin) connectors and replaced it with the other one. It wasn't even made by the same company (replaced a Seagate with a Western Digital) and it wasn't even the same interface (firewire on the Seagate and USB on the WD). It worked like a charm. I know very little about this stuff, so granted, I thought it was risky... but as long as your drive has the same voltage/amp rating as the board (check the power supplies and sides of the drive inside the casing), you should be all set to make the switch. I checked and all mine require the same amount of power, and I don't think that's a coincidence. Unless you're working with a big raid array or a larger drive, I'd expect yours to as well.
If you don't have a second HD, I would suggest maybe purchasing a cheap one just for the board at least to salvage your data.
Posted on Apr 05, 2009
The blue light keeps flashing on and off on my Seagate 4Tb XHD. It won't show up on the finder as connected. What causes that?
follow these steps:
  1. Make sure the computer and external hard drive are powered on.
  2. Safely remove the drive from the computer (if possible).
  3. Disconnect the external drive's USB or FireWire cable.
  4. Disconnect the power supply plug from the external drive.
  5. Power off the computer.
  6. Disconnect the computer's power supply cord for 60 seconds.
  7. Reconnect the computer.
  8. Power on the computer.
  9. Connect the power supply to the external drive.
  10. Connect the drive's USB or FireWire cable and check for detection.
If that does not correct the behavior, and if the drive is also not detected by your computer, the blinking light is probably a symptom of a larger problem. If those steps do not return the drive to correct function, it is very possible, even probable, that the drive has failed and needs to be replaced
Dec 22, 2014 | Seagate Computers & Internet
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
I was removing the video card to tighten a nut. I unplugged the power cord and pushed in the power button to drain excess power, notice the solid green light went to flashing. I then removed video card to...
Open it up again. Take the video card out. Take the Ram out. Unplug the hard drive. Unplug the other drives. Unplug the network card(s). And unplug anything else that is tied to the motherboard. Now plug it all back in snugly.Finally,turn it on. It should be fixed.
Nov 23, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
Green power light is flashing and red light next to it stays lit
A flashing green on printer light generally means its waiting for a command for instance, push print, stop etc... also check that the pause button has not been pushed. if so depress again to release printing process
Jul 11, 2010 | Epson Stylus Photo 1280 InkJet Printer
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Vantec Nexstar 3 HD not being recognized on comp
Hi, I had this same problem - blue light flashing and the drive not being recognised.
The problem was with the power cord, not the drive.
I solved the problem by unplugging the connection on the power cord between the outlet end and the power brick section, and re-plugging them after flipping one of the ends over.
The drive was now getting power correctly and spun up and was recognised as usual.
Apr 17, 2009 | Vantec NexStar 3.5in External Hard Drive...
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive Logo
912 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
