Question about Brother SE-270D Computerized Sewing Machine
MFC Applicaton stopped working
I don't know if you can help me or not but i'm getting an error that says MFC application has stopped working. It's coming up when I open one of my embroidery programs. I have deleted the program and reinstalled but i still keep getting this message.When I reinstalled the PED BASIC program (brother embroidery card reader program) it still comes up with the error. It's saying on my problem sheet that the Brother Driver is not compatible with my version of WIndows.... I'm running it on my lap top. That's all it says..I get a pop up that just says MFC APPLICATION STOPPED WORKING, windows will close program and find solution...it never shuts down until I do it. My machine is the Brother SE-270D, but the problem is with the PED BASIC software. And I've narrowed it down to the drivers...something is not compatible with them!!
    Problem Solver:
  • 5 Answers
If your operating system is Windows 7, please try this tutorial (it's in an easy spanish): http://autorneto.com/tecnologia/gadgets/brother-en-windows-7/
Else, if you don't have this operating system, please specify which one do you have.
Hope my tutorial helps; write comments on the tutorial's page and here also. Make it known if it worked for you (only if you have Windows 7).
Good luck
Posted on Aug 19, 2009
SOURCE: PED basic card
I had a similar problem and message on my Deco 650 and found that I misunderstood writing to the disk on my PED Basic. When I pressed the write button it came up with a note saying that it would delete all designs on the card. I'd just spent hours learning how to use it (?) before I realized I had not truly 'written' the patterns to the card.
Sandy
Posted on Jan 18, 2009
  • 9 Answers
SOURCE: re- brother PED card reader for machine embroidery
Re write the card ?
Posted on Nov 18, 2008
  • 29 Answers
SOURCE: Instrucitnos for Brother SE-270D Timing Problem
This is not really something you can do yourself (been there, tried that!). The machine has to be almost completely disassembled to get to the timing mechanism. Trust me, it's worth the 30.00 to have it timed.
I think http://www.allbrands.com has a generic timing explaination for sewing machines (use the drop in bobbin one)...I found it easy to follow...but once I realized I had to unplug all the components for the computerized functions... I took it in to the dealer. If you contact Brother & your machine is under warranty, they will pay for the repair (they paid for my first two re-timings). Now I know you HAVE to use BOBBIN thread that is 60 WT only in the bobbin. You will continue to have problems if you don't. Also, this machine uses the class 15 bobbin, but make sure its model number SA156A, which is a hair taller than the SA156 bobbin..both are class 15, but the tiny difference is very important.
Posted on Aug 12, 2008
  • 736 Answers
SOURCE: I'm getting an error that says MFC application has
if you have win 7 or vista on your laptop .. the program may be written for win xp .. if so, you can check to see if ugraded software is available from brother for your operating system .. .. or you can load your present software using windows " Compaaibillity Mode" chose XP or whatever operating system the brother software was written for .. right click on your program loader on your disk (setup or whateve) . then select "compatability mode"
Posted on Jan 27, 2010
  • 32 Answers
SOURCE: brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Posted on Feb 05, 2010
Suddenly LS-2000 stopped working, just a month back we bought it. Even the bulb is not glowing, please someone help me with this..
Take it back to the store, get a replacement. If it is under warranty you don't want to be futzing about inside. Just go get another one.
Oct 14, 2012 | Brother Sewing Machines
Loud clunking noise when sewing. . . then it starts to stutter then it stops & gives me an error. It doesn't occur when reverse sewing though
try these suggestions
change the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not damaged or warped
make sure the bobbin is not over full
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin case fits securely into the machine unless it's
a drop in bobbin
if these suggestions don't help then the machine may need to be
checked at a repair shop
Sep 11, 2012 | Brother CS6000i Computerized Sewing...
How to fix E2 code on Singer Fashion Mate 5500 sewing machien?
I would take it back right now. Don't wait for another E2 error. I would take it back and get a different brand of machine.
Sorry... but Singer doesn't have the quality it once had.
Aug 08, 2012 | Singer Sewing Machines
My on off switch went. it is now loose and wont work. Where can I buy a replacement? It is two weeks until Christmas and my daughter is using this to make her Christmas presents.
You will need to find a local Sewing Service Centre and see if they can help....I don't even know what continent you are on !!
I stopped taking new servicing orders end of last week to get clear for Christmas....borrow a machine if you need to, but DO NOT use with a faulty switch.
Dec 13, 2011 | Euro-Pro Deluxe 6130 Mechanical Sewing...
I have a brother pe 700 embrodery machine and it will work for maybe 10 min and then it has error safety device has been activated i have cleaned it and there are no tangled threads
my pc700 will work for a whaile than the thread gets thiner and thiner at the needle I'll stop the machine a cut the threas pull thread out and it's frayed if I don't catch it it'll break up in the machine than I have to pull the thread up the top what's the proble I jusy got it back from the shop worked not even an hour on it
Jan 07, 2011 | Brother PC-6000 Pacesetter
Application error when trying to open futura
Futura installation integrity might be damaged, you need to uninstall everything Futura related, reboot pc and install from the beginning.
If you already did reinstall Futura but still get the error, you may launch troubleshooting utility and send its report to Singer.
Mar 23, 2010 | Singer CE-200 Quantum Futura Computerized...
I'm getting an error that says MFC application has stopped working. It's coming up when I open my PED-Basic. I have deleted the program and reinstalled but i still keep getting this message. When I...
Jan 27, 2010 | Brother SE-270D Computerized Sewing...
Can't balance top/bottom thread tension-model 158.Bottom thread is a straight line. Have increased top tension to the stop. No effect.Have reduced bobbin tension until bobbin and case fall freely when held...
I disassembled the top thread tension controller consisting of 12-13 pieces, including 2 springs. Since they all fell out on the table I spent about 2 hours learning the proper stacking order on the central shaft.
With a combination of reasoning based on each unique piece shape and trial and error I put it back together, adjusted top and bottom tensions according to the instruction booklet for the machine, tested some stitching, made final adjustments and all worked well.
I don't know what was changed in the process but it worked.
Don
Sep 03, 2009 | Kenmore Sewing Machines
Communication error for Customizer 2000
Is this the first time you've tried to use the Reader/Writer?
I ask only because many people don't realize that a necessary step in setting up communication is to set the "COM Port" designation within Customizer/Digitizer.
If you've not done this, within either application, go to >ScanCard>Communication Settings> and choose the COM Port you want to use (you can find out what COM port the cable's using by going to your Start/Task Bar in Windows>Control Panel>System>Hardware>Device Manager>Ports (COM & LPT). There, you should be able to see what port your cable's using.
Then set that COM in your application's Communication Settings dialog box.
Hopefully, I made sense here and explained it well. If I didn't, please let me know where I went goofy and I'm more than happy to clarify!! :)
Also let me know if that does NOT solve your problem!!
Jul 02, 2009 | Janome Memory Craft 9000 Computerized...
Machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Apr 16, 2009 | Sewing Machines
Brother SE-270D Computerized Sewing Machine Logo
3,023 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
