Monitor interior power supply
Is there a dell replacement power supply that will work in a MAG Innovision LT1919WDb?
  • jose johnny Jan 02, 2009
    donda puedo encontrar una vaio para un monitor viewsonic va520
    hola como estan si alguien me puede ayudar con un monitor viewsonic va520 la tarjeta de video se le quemo la vaio por favor ayudenme gracias.
Elow
Posted on Sep 27, 2008
I need a key to open the cover case on a hp w1907v lcd monitor or a suitable alternative.
Many thanks, John mc
Posted on Aug 31, 2009
LT1919WDB FLAKEY PICTURE
When the LCD Controller cable is diconnected from the LCD panel, the screen should be completely white due to the Liquid crystals do not have the bias voltage to block the backlight from coming through the front of the screen. Unless you have intermittent shorts circuits on the LCD controller board (part of the LCD panel) that load down the 5vdc (logic power supply). The capacitors on all the board look OK? See the pictures of bad caps in the monitors here and post back what you see on your boards so we can go further with troubleshooting.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 09, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
I bought a mag innovision model 780 monitor at a garage sale to use with my ACER mini laptop. This monitor has a manufacture date of January 2003 - it did not come with a power supply. Where is the power...
With Most Mag monitors, the plug is a simple 3 prong on the bottom side of the monitor. Though it isn't proprietary, it isn't a common power plug either. Radio Shack does carry this type of cord. Just look on the bottom side of the monitor itself. the three round plug "thingy" is where the 110v plugs in straight from the wall. Best of Luck!
Feb 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Monitor not working with desktop
The pc does not power the monitor. It has to be independently plugged into an electrical outlet.
Apr 10, 2009 | Computers & Internet
My mag Innovision flat lcd monitor is blank after 3 seconds..
It is not easy. I slip a knife in the bottom edge and slowly work my way around the bottom opening it a little by little. Once you get the bottom and part of each side you can push the plastic towards the top and it will pop off. There are plastic clips holding the bezel down. I always break a couple on opening, but at least the monitor gets fixed. This is not made to open, so good luck.
Jan 29, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
MAG LT776s Monitor power cord
Your description is the external power supply/adapter for a Mag Innovision LT776s 17 in. Flat Panel LCD Monitor. One may be purchased here. Aftermarket/replacements may be found here, here or here. Pls verify that the plug matches the jack and the polarity is correct. Additionally, if it would be a replacement, pls check the voltage and current rating.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Mag Innovision LT776s 17" LCD Monitor
MAG Innovision LT1919WDb flat screen goes black
I had the same problem. I contact the manufactuer and they refused to fix it. They said it would cost an additional $100 to have it fixed. I have not even had it a year. I thought products sold in America were suppose to last longer than a year? What has happened to companies standing behind there products. Beware of this monitor!!! DO NOT BUY IT!!! LT1919WDB
Jan 30, 2008 | Computers & Internet
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision 765S power supply light blinks and monitor power led blinks and no picture
I'd suggest looking at the mainboard. I assume the blink is rapid? A slow on, followed by a short off and back on again is normal. The fast blink thing is a mainboard issue, and the absence of blink (or light) is power "supply dead."
There is a problem transistor on the mainboard that seems to be the problem most of the time. Replacing it takes about 5 minutes if you have the tools and the talent, and the parts cost under 3 bucks at Radio Shack. Just pick up a pack of NPN switching transistors and de-solder / solder your way to a working monitor. There's usually only one on the board, so it's easy to spot.
Nov 18, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision LT576s won't power up
Clearly your monitors are evil. Try turning them on at home and see how you fair out. :)
Cheers,
Mike
Oct 07, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Computers & Internet Logo
969 people viewed this question
David Payne
David Payne
