Question about Dryers
I NEED YOUR HELP
SO WE HAVE A FRIGIDAIRE FER641FSO ELECTRIC DRYER AND WHEN I PUSH THE START BUTTON IT JUST MAKES A BUZZING NOISE AND DOESN'T START. WHAT IS WRONG?
  • Anonymous Dec 06, 2008
    Same issue. I bush the start button and it buzzes.
  • hotwirehenry Feb 03, 2009
    I guess the motor is close to dieing. I can still get the thing to work but I had to tape down the "off" switch on the inside of the door. Then I manually rotate the barrel inside while holding down the start button. It will go then. Anyone one got an idea on how to properly fix this? Should I get an air compressor and blow out the motor? Any suggestions on how to access the motor any easier from the back? Do I have to remove the motor, how do I access that? Does this kind of motor have contact brushes inside that can be replaced? Is that the problem or is the motor just going bad from use? It's only 2 years old.
  • 943 Answers
Hi tanks for the question you could have a bad motor or something caught in the blower i would check the blower thanks the appliance doc
Posted on Sep 27, 2008
Dryer doing nothing
Your dryer is sensing a problem, but not being specific about it. Check that you can turn the drum first to make sure that it hasn't wegged in place. But it sounds more like a control board - from the limited indications you are giving us.
Jun 20, 2012 | Frigidaire Electric Dryer
My Frigidaire dryer (Gallery series) will not start. It makes a buzzing noise every time i pres the start button.
This is a indication that the motor had shorted out to ground and everytime you press the start button the start and run windings of the motor are grounding out. You'll need a new motor for this fix.
Dec 14, 2010 | Frigidaire Electric Dryer
When i push the start button all i get is a buzzing noise
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2010 | Frigidaire FER311FS Electric Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Dyer was grinding, then won't run
Sounds to me like you motor has froze up. Is there any smell coming from the dryer? The fuse would not cause this. A fuse would make the dryer do nothing when you hit the start button.
Nov 21, 2008 | Roper REX4634KQ Electric Dryer
Dryer will not start when start button is pressed, makes a buzzing noise
open the door set the timer fo 60 min reach in while holding down the door switch give it a good spin hard clockwise and tell me what happens
Feb 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
225 people viewed this question
Top Dryers Experts
