A
Anonymous Posted on Nov 10, 2011
T2265 DMP Paper setting issue
I Want full oracle report printing in one page, but it's printing in 2 pages
4 Related Answers
A
Anonymous
  • Posted on May 11, 2008
SOURCE: TALLY T2250 PRINTER
HOW SETUP TO WIN/XP STEP BY STEP
Swarnava Palit
  • 114 Answers
  • Posted on Jan 30, 2009
SOURCE: error in eject page
dont use LF use FF to forward a form. if you use LF then set the topper form again.
Anonymous
  • 330 Answers
  • Posted on Oct 14, 2009
SOURCE: problem in printing character mode report on epson fx 2175
first take printer setting ...... press online botton( paper feed botton i am not sure which one ) and switch on the printer it will print all setting... ckeck any tear off setting is there .... off the option ....fallow the instraction to change any settiing .....
Anonymous
  • 29 Answers
  • Posted on Nov 17, 2010
SOURCE: ms word does not print properly on tally 2250 printer
you need to create a forms for your specified paper size.
1.open printer and faxes in win xp.
2.file...server properties...create a new form(check)
3.type a name for forms
4.type a size in below boxes...(like 10 x 12 paper , width is 10 inch, height is 12 inch)
5.save it
6.close
7.rht click the printer...device setting tab... select a form name in the tray .
8.it will work
Why does Xerox 7335 truncates output from Oracle PDF?
It may not be the printer and I did some research on Oracle and this seems to be a common issue.
I pulled this information off an Oracle knowledgebase it may not resolve your issue and there is more info on the following site if you want to investigate further:
http://docs.oracle.com/cd/E23943_01/bi.1111/b32121/pbr_uxprt009.htm#RSPUB75727
NOTE:
If you're printing to the Xerox MFD with a PS (postscript printer driver) you could try installing and printing using the Xerox PCL driver for your computers operating system. If you printing reports from a mainframe this may be an issue at the mainframe level in which case I would engage your companies IT department for assistance.
Any one of a number of possible causes may account for the truncation of fields.
  • Check the field and determine if it is allowed to expand.
    1. In Oracle Reports Builder, double-click the field in the Paper Design or Paper Layout view to display the Property Inspector.
    2. Find the Horizontal Elasticity property.
    3. If it is set to Fixed, you should change it to Variable or Expand.
    4. Run the report to the printer.
    5. If it still truncates, it could be that the field requires multiple lines.
    6. Return to the Property Inspector for the field and check its Vertical Elasticity.
    7. If it is set to Fixed, you should change it to Variable or Expand.
    8. Run the report to the printer again.
  • If the right most fields on the page are always the ones truncating, it could be an issue with the printable area of the printer. If you are using a PCL printer, then you will have to estimate the size of the printable area and resize your margins accordingly:
    1. Open the report in Oracle Reports Builder.
    2. Go to the Paper Layout view.
    3. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins.
    4. Click and drag the black line to the left approximately 0.5 inches.
    5. Save and run the report to the printer again.
    6. If necessary, repeat steps 4 and 5 to determine approximately where the printable area boundary is located and then ensure that your report body fits within that area.
  • If you are using a PostScript printer, you can get the printable area boundary to appear in the Paper Layout view as follows:
    2. Choose File > Page Setup.
    3. Verify that the margins are small and that the orientation is correct.
    4. Click OK. The Paper Layout view should now be able to read the boundary.
    5. Go to the Paper Layout view.
    6. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins. A black hashed line also appears indicating the boundary of the printable area.
    7. Ensure that the thick black line is inside of the black hashed line. If it is not, click and drag the black line inside the printable area.
    8. Click the Margin tool to leave margin mode.
    9. If necessary, reposition your fields to fit within the new body boundaries.
    10. Save and run the report to the printer.
  • For PCL, if it is still truncating, try using a fixed space font instead of a proportional font. Sometimes PCL printers have problems interpreting proportional space fonts and it leads to truncation. You should try using a fixed space font, such as Courier, and possibly font aliasing.
    Note:
    Default layouts are built against a generic printer. Each printer has its own printable area. As a result, you may have to reset the report to fit the printer. Ideally, if you know the various printers you will be using, you can design the report from the start to fit the printer with the smallest printable area.
Only blank pages printed out of Oracle
does the machine print ok with word, web papge pdf, etc if so its the oracle issue, or just the oracle file try other files?
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Hp officejet 4500 will not print from mac ibook g4
HP Officejet 4500 (G510) Series and 4500 (K710) Series All-in-One Printers - The All-in-One Does Not Pick Up or Feed Paper Issue The product does not pick up or feed paper from the paper tray. How to use the solutions in this document To resolve the issue, try each solution in this document in the order presented. c01733891.gif IMPORTANT : Each time you try a solution, try to print a self-test report to determine if the hardware is functioning correctly. To print a self-test report, use the steps in the following table. How to print a self-test report
  1. Load plain, white paper in the paper tray.
  2. Press and hold the Cancel button (c01235250.gif ) on the product control panel.
  3. While holding the Cancel button (c01235250.gif ), press the OK button (c01961874.gif ). The self-test report prints.
NOTE: Refer back to the steps in this table after attempting each solution. Solution one: Reset the All-in-One
  1. Disconnect the power cord from the back of the product.
  2. Wait 30 seconds.
  3. Reconnect the power cord to the back of the product.
  4. Press the Power button (c01602202.gif ) to turn on the product.
  5. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the test page prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the test page does not print , continue with the next solution.
Solution two: Check the paper The condition of the paper or the amount of paper loaded might prevent the rollers from picking it up and feeding it through the product. Use the following steps to check the paper in the input tray.
  1. Remove any wrinkled or damaged paper from the input tray.
  2. Make sure that all the paper is the same size and type.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper contains from 10 to 25 sheets of paper.
    NOTE: Do not overload the input tray. Make sure the stack of paper is shorter than the top of the paper width guide.
  5. Insert the stack of paper into the product, and then gently push the paper width guide snugly against the paper. Figure 1: Load paper c01970609.gif 1 - Load paper 2 - Adjust the paper width guide Illustration of loading paper and adjusting the paper width guide
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution three: Check the print settings The paper settings in the print driver must match the paper size and type loaded in the product. Use the following instructions to adjust the paper settings.
  1. In the software program you are printing from, click File .
  2. Click Print , and then click Setup , Properties , or Preferences .
    NOTE: The specific options might vary depending on the software program.
  3. Click the Features tab.
  4. In the Basic Options pane, select More from the Paper sizes drop-down list.
  5. Select the size of paper loaded in the product, and then click OK .
  6. In the Basic Options pane, select More from the Paper type drop-down list.
  7. Select the type of paper that you loaded, and then click OK .
    NOTE: These changes do not change the default print settings. The print settings revert to the default settings the next time you open the program.
  8. Change any other print settings necessary, and then click OK .
  9. Click OK to print.
  10. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution four: Clean the rollers Follow these steps to clean the rear rollers and the pick rollers on the HP product. Step One: Clean the rear rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 2: Remove the rear access door c01961876.gif Remove the rear access door
  4. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the paper rollers. Rotate the rollers with your fingers to clean all the way around. Figure 3: Clean the rollers c00246512.jpg Graphic: Showing paper rollers
  5. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely. Figure 4: Access door rollers c01590938.gif Access door rollers
  6. Allow the rollers to dry completely.
  7. Reattach the rear access door. Push the door forward until it snaps into place.
Step two: Clean the pick roller
  1. Remove any paper from the paper tray.
  2. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 5: Remove the rear access door c01961876.gif Remove the rear access door Figure 6: Rear rollers and location of pick roller c01976220.gif Image: Rear rollers and location of pick roller
  3. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the pick roller. Rotate the pick roller upward with your fingers to clean all the way around. Figure 7: Pick roller c01975068.gif Image: Pick roller in the product
  4. Make sure that the pick roller and the rollers around it are clean, free of paper bits, and rotate freely.
  5. Allow the pick roller to dry completely.
  6. Reattach the rear access door. Push the door forward until it snaps into place.
  7. Load the tray with plain white paper.
  8. Reconnect the power cord to the rear of the product.
  9. Press the Power button (c01602202.gif ) to turn on the product.
Solution five: Service the All-in-One
Lexmark T640 LCD blank..
To check if this is a hardware issue, please print a menu settings page. The purpose of this diagnostic is to check if this is a software issue or a hardware issue.
1. Press Menu to display Menus.
2. Press "down" until the "check" appears next to Reports.
3. Press "Check".
4. Press "down" until the "check" appears next to Menu Settings Page.
5. Press "check".
The message Printing Menus Settings appears on the display.
The printer returns to the Ready state after the menu settings page prints.
If the menu settings page printed without the dots, this would be a software issue. In that case, please call our Technical Support Hotline on (800) 539-6275.
2answers
I am using quickbooks 2005 and am trying to print full page checks. I am getting a 'paper mismatch' error and cannot print my checks.
Welcome to FixYa.
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error.
How do you load your check in the printer?
Keep me posted.
Jas247
I guyz. my hp officejet printer works very fine as in you send document to the printer but the most amazing thing is that afetr printing and you discover there is no ink on the printer page. Please...
Hello
Before actually printing your report, use the Print Preview function to see how it will look. If there are blank pages, you will see them in Print Preview.
To use the Print Preview function, simply open the report, click on the "File" menu and choose "Print Preview" from the file menu. You will then see your report just as it will look on the printed page.
Scroll through the report for blank pages. If you see blank pages, it is an indication that the data on the report is wider than the paper you are using. You can use your printer properties to change the size of the paper if you wish. If you have access to legal-size paper, you may be able to print the report on the larger paper. If legal-size paper is not an option, you will need to adjust the margins so that the blank pages are eliminated.
To adjust the margins of your report, click on the "File" menu and choose "Page Setup" from the drop-down box. Go to the Margins tab and adjust the margins as needed. It may take a bit of experimentation to get the margins just right; toggling back and forth between Print Preview and Page Setup will make the process faster and easier.
Click on the "Page" tab and choose either portrait or landscape orientation. Changing the orientation to landscape may allow all the fields to print on the same page, thus eliminating the blank pages and saving your paper.
2helpful
Problem in printing character mode report on epson fx 2175
Canon ir 2200 print from oracle
ive had this before its under your printer setting tools you have to set that copier for tray 1 or letter turn off automatic
FAX CONFIRMATION PAGE
Touch ADMINISTRATION then touch CONFIGURATION PAGES then MENUMAP and that will print a guide for you to look for FAX REPORTS and when to print them. You can also have a thumbnail put on a report
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
