Trying to fix philips MT2400 PC. No recovery discs - any idea where I can download from?
Hi I was given the same computer Philip MT2400 to repair, but they had managed to screw up the recovery partition, I tried too do a fresh install of xp pro sp3 and it got to 8min left and stayed there, wouldnt get past the point, tried another xp pro cd with sata drivers that where added same thing, in the end i gave up and bought the DVD to use.
I can make an image of the DVD and upload it for you glaude it would be in an spanned rar file due to limits on where i can upload. It would take a couple of days to upload due to the size and content even with the rar compression. so leave a message here and i'll upload it for it.
Posted on Dec 15, 2008
  • Seth Meyers
    Seth Meyers Apr 01, 2011
    any chance you could let me know where you uploaded that to
    thanks
    Zed
I was given one of these yesterday. It was a working unit but I wanted a clean copy of the O/S. Simply create the recovery disks from a utility (I think it was 'recovery options' under 'all programs'). You need 4 x cd's or 1 x DVD - although it would not regonise any blank DVD's. It takes about 30 minutes from starting the recovery to a full recovery back to disk. The manual warns you not to use Fdisk or any other partitioning s/w or the recovery will not work. You get options to do a non-destructive or destructive recovery.
Posted on Apr 20, 2009
  • 45 Answers
If you have important files and data that you would like to keep, your best solution is to perform what is called an "in-place upgrade", also known as a repair install. The disadvantage of this is that some malicious files created by the Sasser worm (and any other infections you might have) may remain on your hard disk.
The following two articles from Microsoft explain how to perform a clean installation (by booting from the Windows XP CD) and how to perform a repair install, respectively:
How to install or upgrade to Windows XP
How to perform an in-place upgrade (reinstallation) of Windows XP
If you decide to do a repair install, your user account folder will remain in the place it originally was. So, for example, C:\Documents and Settings\yosser. In that folder there will be your "My Documents", "Desktop" and other data folders that you originally had. If you decide to perform a repair install, disconnect your computer from the Internet. Once you have finished installing Windows, update it to Service Pack 2 or 3 and follow all of the steps and advice on this website provided by Microsoft.
If you decide to do a clean install, the updating and protection steps that I just mentioned still apply. The caveat is that to do either of these two types of reinstallation, you are required to have a Windows XP CD at hand. It varies from manufacturer to manufacturer as to whether they supply you with this disc. Otherwise, you may be able to recover your machine by running the built-in recovery routine. Check the user manual that came with your computer.
Posted on Sep 26, 2008
Ntdlr is missing
You can download and burn the Hiren Boot CD to fix this. However in most cases you'll get another error. Re-installing the operating system is your best option. If the recovery console doesn't work (F10) then you may also need to replace the hard drive. If you don't have the recovery discs. You can order them from HP.
Jan 30, 2013 | HP Pavilion A820n (PP165AA) PC Desktop
My gateway laptop won't reboot after system recovery
I would put in a Windows disc and see if that prompts windows to start and/or reinstall. Actually, can you send me the recovery disc via download? I am trying to fix my old laptop and cannot find the discs. lilly.murphy@yahoo.com Thanks much!
Nov 30, 2012 | Gateway NV55S04u PC Notebook
I downloaded files on my 8gb philips go gear SA52xx product connecting it to a pc and when i unplug the USB connection of my device after everything it has since then frozen and refusing to work even...
Hi leefordnarte,
You can find a lot of valuable resources on the Philips Support Site...I am not sure which specific model you have, but the Product Support Page for the SA5285/37 can be found here:
http://ow.ly/5XLe9
For the issue you described, I would attempt a Repair/Recovery - this process will restore your player to factory settings, as well as update the firmware in the process.
Try the Philips Device Manager software (found on the support site www.philips.com/support if you do not have your original software disc):
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
Hope this helps - if so, let me know by rating this solution. If you have any additional questions or need assistance, you can reach Consumer Care at 1-888-744-5477.
Aug 08, 2011 | Philips Audio Players & Recorders
I have a philips mt2400 desktop pc and my problem is i reloaded software using the windows media center software cds that came with it, but unfortunately it looks like there are no drivers with the...
Not sure what you have done...have you re formatted the HDD??
If so then you will need to search the vendors site to get the updated drivers.
To get the mobo info download / install CPU-Z and it will supply all hardware info.
May 17, 2010 | Computers & Internet
Philips mt1800 displays problems with startup
You can't fix that anymore, your windows copy is now "corrupted or impotent".
If it won;t work on safe mode, probably your system files are at a bad condition.
Recovery disc might get you to startup again, but if ever there is a virus it will just happen again.
I advise you to reformat if you don't have anymore files to save.
If ever there is, well... maybe get a linux live CD so you can browse through your hard disk again.
Hope I helped, cheers.
Feb 15, 2010 | Computers & Internet
Trying to reset a PCto factory defaults
There is a neat site:
http://www.user-guides.co.uk/asp/search.asp?keywords=User+Guides+Phillips+MT2400&recor=1
They have everything you need. Look at the Bios jumper ad reset it.
Hope this helps.
Jan 27, 2009 | Computers & Internet
I CANT DOWNLOAD ANY MORE
Make sure you install the disc with the Philips Device Manager on it first (or grab the device manager from Philips' website).
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab. Then click on the “Repair” button to start the repair process. Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in. If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Dec 12, 2008 | Philips SA5125/37 MP3 Player
Need recovery disc for an e-machine T2896
I don't know where you can download a recovery disc, BUT I do know where you can download most of the drivers you'll need to restore the PC to it's original condition. Just visit eMachines Support for the T2896 at this link. Then, click Download and you'll see all of the drivers. Click each driver you need and then burn a CD of those drivers, along with any documentation. Put that disc away -- and it can serve as your recovery CD.
I hope this helps. If it does, please rate the solution offered. My goal is always FixYa or Helpful, never TFT or IA. Regards,
Char1ieJ
Nov 24, 2008 | E-Machines (T2878) PC Desktop
Need to do system recovery on philips freevent x53 problem damaged recovery disk
best not to use a recovery disc as they will erase alot of info, see if you can find a windows disc and use your code off your sticker, when you insert the disc, it will ask if you want to go to recovery mode, say no, go to fresh install and when it says you already have windows ask it to fix the current install, 90% of the time this works
Jun 14, 2008 | Computers & Internet
When I run System Recovery DISC the programme tells me '' The Disc I have loaded is not empty' yet is a Disc I purchased specially for creadting recovery discs. I am using a HP PAVILION Computer M...
A system recovery disk is for recovering a failed hd. try booting up on the recovery disk. If it works U will loose all programs and data loaded since its creation.
May 26, 2008 | HP Computers & Internet
Computers & Internet Logo
942 people viewed this question
David Payne
David Payne
