Question about HP PSC 1210 All-In-One InkJet Printer
Scanned picture I cannot find a picture that I have scanned. It is not in my documents. Where is it?
  • HP Master
  • 4,338 Answers
Did you name it? Do a search for it. When it is found you will see the path .
Also, you can download Picassa , a free photo program which organizes your pics and does alot of other things.
Posted on Sep 26, 2008
How do I set up the scanner on my HP J3680?
use the CD that came with the printer.it has the full feature software that will enable the printing and scanning capability of the printer.
- insert the disk in the CD-ROM drive - hit install - reminder:do not plug in the USB cable yet unless you are prompted by the installer to do so - after installing the software , make a test print to prove the functionality of the printer. - then we move on to test the scanner -there are two ways to make a scan: 1. click on the solution center icon on the desktop. 2. in the solution center , there are two buttons for scanning: scan pictures and scan document 3. scanned documents are saved under the MY SCANS folder. file path is : my documents or simply documents---->MY SCANS 4.for scanned pictures file path is
my pictures or simply pictures---->MY SCANS
Jun 27, 2011 | HP J3680 Officejet All In One Printer
Tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
on Dec 08, 2009 | Office Equipment & Supplies
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    How do i scan a document from my c3180?
    Here are the steps to scan documents to your computer
    1. Turn on your computer, wait for it to boot up, then turn on your printer.
    2. Locate the " HP Photo and Imaging Director " icon on your computer and double click it.
    This icon was placed there when you installed your printer.
    3. After double clicking on the icon, a menu screen will appear showing the scanning options
    available on your C3180 printer.
    4. Place your document or picture on the printer's glass top and close the lid.
    5. Click on the appropriate selection from the menu screen ( Scan Document or Scan Picture )
    6. The scanning process will now take place. The scanner will make two passes. The first pass
    will allow you to judge the accuracy of the scan and to make changes, if necessary, from your.
    monitor. The second pass is the acceptance of the document/picture to the computer.
    7. Scanned documents can be viewed in the " My Documents " folder, scanned pictures can be
    viewed in the HP Photo Gallery and the My Pictures folder.
    I hope this was of help to you.
    Feb 15, 2011 | HP Photosmart C3180 All-In-One InkJet...
    L want to scan a document with hp office jet 4355 how do l get scaning option from my computor
    1.Turn on your computer and wait for it to boot up, then turn on your printer.
    2.Locate the " HP Image Director " icon on your computer and double click it.
    ( This icon was placed there when your printer was installed on your computer )
    3. A screen will appear showing the scanning options available on your printer.
    4. Place your document or picture on the printer's glass top.
    5. From the HP Director screen, click on the appropriate button to start the scanning operation.
    The scanner will perform two passes, the first; is to preview your document or picture and to
    make changes, if necessary, the second; is the final acceptance of the document or picture
    and save it on your computer.
    All scanned pictures can be viewed in the HP Photo Gallery and the My Pictures folder
    Documents can be viewed in the My Documents folder.
    I hope your scanning goes well.
    Feb 07, 2011 | Office Equipment & Supplies
    I have a HP Photosmart 2575 xi all in one printer and I need to be able to scan documents and photos. I have no idea how to do it. How do you scan these things. I use the printer and the copier but have...
    1. Turn on your computer, wait for it to boot up, then turn on the printer.
    2 Double click the "HP Photo Imaging Director" icon on your desktop ( placed there when your
    printer was installed on your computer ). A menu screen will appear showing the scanning
    options of the printer.
    3 Place your document or photo on the printer's glass top and close the lid.
    4 From the menu screen, click on " Scan Picture " or " Scan Document "
    When "Scan Document" is selected, a secondary screen will appear from which you will have to
    make choices. After making your decisions, click "Scan" from the listed screen.
    When "Scan Picture" is selected, one scanning pass will be performed, another pass will be
    made after you view the result of the first pass.
    Scanned pictures will go to the HP Photo Gallery and your "My Picture" folder.
    Scanned documents will go to your "My Documents" folder.
    Good Luck with your scanning operations!!
    Jan 21, 2011 | HP Photosmart 2575 All-In-One Printer,...
    How doI scan something?
    To scan something from your printer to the computer you should have the hp solution center installed in your computer double click and open the solution center place the document or the picture that you wnat to scan on the glass bed of the printer (the text content should face towards the glass)
    now click on the scan document or scan picture button on the hp solution center a window will come up click n the scan button then a window will come up showing the preview of the scaned document or picture click finish to finsh the scan
    now you can view your scan by going to the MY SCAN folder in MY DOCUMENTS
    Jul 30, 2009 | HP OfficeJet J4580 All-In-One Laser...
    Scanning
    u can scan it as a document and just adjust the settings from the computer to scan it in as colored document
    Jul 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Scanning
    by default it is save in my picture but when we scan then from brouse we can select the location from the brouse options
    Jun 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
    Scan in word 2007 documents using vista
    From Word 2007 Help:
    The From Scanner or Camera option for scanning documents and pictures is not available in Microsoft Office Word 2007. Instead, you can use your scanner to scan the document, and then you can save the file to your computer.
    After you scan the document, you can use Microsoft Office Document Imaging to create a version of the document that you can edit.
    Important The first step is to install Microsoft Office Document Imaging, which is not installed by default.
    Mar 08, 2008 | Canon Pixma MP500 All-In-One InkJet...
    HP PSC 1210 All-In-One InkJet Printer Logo
    22 people viewed this question
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
