It is showing i.e, show in mirror, when we open the tv showing one option to select the service mode nd choose option, but i cannt understand what is to be fix it
I had a similar problem, checked all of the TV's control settings only to find out that my cable box had an independent "mute" function that automatically turned on the closed captions when activated. Once I found that and turned it off, all was fine.
Check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit which you will need new main board. Please post back what you find. Parts: www.shopjimmy.com http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://s807.photobucket.com/home/budm/allalbums
To reverse the picture on your SEIKI SE32HY10 TV, you can try the following steps:
Press the "Menu" button on your TV remote to access the main menu.
Use the arrow buttons on your remote to navigate to the "Picture" or "Display" menu.
Look for an option called "Picture Orientation," "Mirror," or "Flip Horizontal/Vertical."
Use the arrow buttons to select the option and press "Enter" or "OK" on your remote.
Check to see if the picture has been reversed. If not, try selecting a different option if available.
If you are unable to find the "Picture Orientation," "Mirror," or "Flip Horizontal/Vertical" option in the Picture or Display menu, it's possible that your TV may not have this feature. In this case, you may need to contact SEIKI customer support for further assistance.
To flip the picture on your SEIKI SE32HY10 LED TV, you can follow these steps:
Press the "Menu" button on your TV remote.
Use the arrow buttons to navigate to the "Picture" or "Display" menu.
Scroll down to the "Picture Mode" option and press "Enter".
Select the "Flip" or "Invert" option from the list of available picture modes.
Press "Enter" to save your changes and exit the menu.
If your TV doesn't have a "Flip" or "Invert" option in the Picture Mode menu, you can try accessing the Service Menu to see if the feature is available there. However, accessing the Service Menu requires specific codes and steps, and any changes made in this menu can affect the TV's performance, so it's recommended to do so only if you're experienced in TV repair or have professional assistance.
if it is a SAMSUNG they use the same main boards from 40" to 70"... and what you need to do is get into SERVICE MODE then select CONTRO and look for HV FLIP in not there go back and SELECT on the OPTION it will then show the TV size.. push left or right on your remote until your correct TV size pops up then press return. Now turn off the TV. Turn it on and presto. Done. To get into SERVICE MODE tv must be off. Press mute 1-8-2 then power or press info., menu, mute then power.. remember tv must be off. Let me know if this works or if you need further assistance
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Your TV has three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory. You can activate a Picture Setting by making a selection from the menu. 1 Press the MENU button to display the menu. Press the ENTER button to select Picture. 2 Press the ENTER button to select Mode. Press the ? or ? button to select the Dynamic, Standard, or Movie picture setting, then press the ENTER button. ? Choose Dynamic for viewing the TV during the day or when there is bright light in the room. ? Choose Standard for general TV watching mode. ? Choose Movie when watching movies. Press the P.MODE button on the remote control to select one of the standard picture settings. 3 Press the ? or ? button to select Contrast, Brightness, Sharpness, Color, or Tint, then press the ENTER button. 4 Press the ? or ? button to decrease or increase the value of a particular item. ? You cannot adjust the Tint in DTV, Component or HDMI mode. 5 Press the ENTER button to return to Mode. 6 Press the ? or ? button to select Color Tone, then press the ENTER button. 7 Press the ? or ? button to select Cool2, Cool1, Normal, Warm1, or Warm2, then press the ENTER button. ? When the picture mode is set to Dynamic or Standard, Warm1 and Warm2 cannot be selected. Resetting the Picture Settings to the Factory Defaults 8 Press the ? or ? button to select Reset, then press the ENTER button. ? Each picture mode can be reset. Press the EXIT button to exit.
there ya go if you need anymore help let me know and don't forget to Rate
assuming that you are talking about a memory card ..just get into view mode..and on the menu choose storage ..than options and clear memory card ..or ..just again in view mode..choose a picture and options and when you try to delete will ask for multiple delete ...select them all and delete ..or just insert the card into a card reader and when it shows in the my computer folder open it ..select all pictures and than press delete .. the fastest way though is to simple select in the main menu the storage ...in there select card ..and on options format card ...this will erase all on it ..and format it in the same time for best performance in the device ..
The quickest way to do this is to put your phone into Mass Storage Mode then connect it via the USB cable to your computer. Your phone shows up as a USB Mass Storage Device and you can select the folders you want to download your pictures from.
To set your phone to Mass Storage Mode, do the following:
- Go to the main menu - Select Settings - Then Select Phone Settings - Choose PC Connections from the menu - And then click on Mass Storage.
When you connect the USB cable to your computer, your phone will show up as a USB Storage device and you can just copy and past files to it like you would a USB Thumb drive. If you select the Samsung PC Studio option...your file transfers will take ALL DAY. Just use Mass Storage mode. Good luck.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
1 Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
1 Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
REPAIR: Enter the service mode; under option menu DDP1010 (DDP1011, where
applicable) adjust the V-Flip option back to normal. If the problem continues
replace the DMD Board
