Question about Copystar Office Equipment & Supplies
Troubleshooting a Copystar CG1505 with an error code of C710.
  • Scott Blink Sep 26, 2008
    Yes, the solution fixed the problem. I removed the drum and did not see any problems, reseated the electrics and powered up. It took a while flashing AP, but then came ready and printed normally. Thank you for the help.
  • 4,472 Answers
C710 Toner sensor problem
• The sensor output voltage is outside
the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run.
Try removing and refitting drum and toner.
If that doesn't help the toner cartridge or sensor is damaged.
Please take a moment to accept and rate this solution accordingly.
Thanks,
Lee
Posted on Sep 26, 2008
  • Lee A.
    Lee A. Sep 26, 2008
    Your very welcome glad I could be of assistance. Have a great day.
    Thanks again,
    Lee
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
I have a brand new Copystar 1635 copier... I just plugged it in and it is flashing an error code C-3100
It is toner error, check the plastic strip in toner had been removed, try pulling out and putting back toner
May 03, 2008 | Office Equipment & Supplies
Error cfb30
Try upgrading the latest firmware
Aug 24, 2014 | Kyocera Copystar Fax System M Km-5050...
Kyocera Mita Photocopier KM-1530 Error code AP flashes at start up then C710
When AP flashes the toner is being replenished inside the copier. Wait a few minutes. You need to refill the toner.
Jun 09, 2011 | Office Equipment & Supplies
I need the paper tray (the one after printing for a Copystar cs-1435
You will have to call a CopyStar dealer or a Kyocera-Mita dealer to get that part.
Dec 09, 2008 | Copystar Office Equipment & Supplies
Im getting an f2 error code in my copy machine sharp 2020
SHARP 2020 F2-31 ID sensor error SHARP 2020 F2-32 ID pattern reading error SHARP 2020 F2-33 Grid voltage error SHARP 2020 F2-35 Grid voltage error
probably need a part
Oct 15, 2008 | Copystar (023-JF503) Fax
Copystar 1635 Copier
C3100 Scanner carriage problem The home position is not correct when the power is turned on or copying the document placed on the contact glass. Poor contact of the connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Defective scanner home position switch. Replace the scanner home position switch. Defective engine PWB. Replace the engine PWB and check for correct operation. Defective scanner motor. Replace the scanner motor
103 people viewed this question
Top Copystar Office Equipment & Supplies Experts
NewYork kyocera HP...
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
