2003 Mitsubishi Lancer Logo
shaun hunter Posted on Nov 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuel pump my fuel pump wont pump, its brand new and it seems like its not getting any power
Boundless Company Limited
Level 3:
  • Mitsubishi Master 2,122 Answers
  • Posted on Nov 12, 2011
Mitsubishi Master
Level 3:
Answers
2122
Questions
9
Helped
686226
Points
4449
Hi Shaun, that sounds like a defective relay. have a look in the rely pack and identify which controls the pump. check the fuse and if its okay replace the relay. If your problem remains, and the vehicle uses a mass air flow sensor with a gate the problem may be with the micro switch which is opened when the flap moves. Otherwise the problem will be in the wiring. I hope you are aware that the system has a demand circuit and will only give power when the engine is being cranked ad then starts. This is designed to stop flooding if the key is left on and the engine is not started. Otherwise you have a problem with wiring. Regards John
NO FIRE AGAIN
Make sure fuel pump is getting power. Im not sure but I think ignition is wired through fuel pump so if it dont pump fuel it wont spark either
2answers
Fuel pump not getting power f150 1999 4.6L V8
Check the connections for power with a test light. If your getting power to the pump and it doesn't work then it is bad (new or not)
2answers
I have a 91 s-10 that wont run...fuel pump runs and I am getting fuel to the carb all brand new plugs and wires and ignition coil and module and new cap and rotor? fires up and dies out?
The fuel pump relay is at fault. The engine will start running off the oil pressure sensor for the 3rd wire connected to the sensor feeds power to the fuel pump which makes your truck start right up. When the engine achomplish the standard oil pressure as needed the sensor shuts power off by the PCM default system and turns on the fuel pump relay to continue working the fuel pump. replace the relay and you will be driving around again
5helpful
3answers
1979 chevy step van 350 new fuel pump rebuilt carburetor wont sta
remove the fuel line from the carb, put it into a bottle, crank the engine, If the bottle has fuel in it the fuel pump is working properly, if not, check the filter, and the fuel lines to the tank!!!
Throttle body problems
Check the ground ot the pum if power is ok. Also check connector for good connection burning/melting and terminals are in place.
Fuel pump
your fuse might be loose?
1helpful
No power at fuel pump.
have you checked the fuses??
'95 Pontiac Bonneville won't turn over
is the battery good.is the starter turning the engine.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
