Question about Whirlpool Washing Machines
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
Amana top-load washer making loud noise and leaking water from bottom of machine. Machine less than five years old.
    Genius:
  • 1,122 Answers
It sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Posted on Sep 26, 2008
Can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Aug 23, 2009 | Amana ALW480DA Top Load Washer
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Thumping Noise
it must be due to the damaged belt inside the motor. check it out.
thank you
Mar 09, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Ammana nav8805e
If your washer fills but the timer cycle doesn't advance-replace the timer. If your washer fills the time cycle advance, and still not agitating your agitator is at fault.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Ammana washer wont agitate
If the motor is on in the agitation part of cycle and its not agitating your transmission spline is either stripped our your trans. is broken.If the motor is not on and its full of water in the agitation cycle make sure it is not syphoning.Please rate this !
Jun 22, 2008 | Amana NAV5800A Top Load Washer
Admiral Washer Model#LNC6762B71
if water leaks in the tub your water valve need to replace. and thelower bearing. i can let you know how much the parts are.and valve is not hard to replace but bearing is
Feb 18, 2008 | Kenmore 23822 Top Load Washer
Loud increasing "ticks" during spin cycle
take the two screws out of the front bottom panel and fill the machine up with water then get a flashlight and turn to spin and if you look at the top of the transmission behind the motor watch for any water flying out it there is that is the cause of the problem if not you have a bad motor
Jan 27, 2008 | Amana NAV5800A Top Load Washer
Loud noise when spinning
the only part that makes a loud noise is your bearings m8 other than that could be a bra wire stuck inbetween your drum and casing m8
Aug 11, 2007 | Maytag Atlantis MAV6000 Top Load Washer
5 yr old washer is leaking
Ellbee, remove the two screws at the bottom of the front panel and lift it towards you. Two clips on the top that hold it will release. You can now get a good look at the pump. Catriver..post back.
Sep 19, 2006 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
Washing Machines Logo
192 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
