Windowes error code ox80040707,which usually occurs during an installation or upgrade or add and removeing programs how will i remove the error code ox80040707
  • 158 Answers
Download the ccleaner and run the registry cleaner
Posted on Sep 26, 2008
Screen says "Printer error."
Welcome to Fixya
If the error occurred when you were trying to use a feature of EASYSHARE Software:
  1. Run the Repair utility:
    1. Select Start > Settings > Control Panel > Add or Remove Programs.
    2. Click KODAK EASYSHARE Software.
    3. Click Change.
    4. Click Next.
    5. Select Repair, then follow the instructions.
  2. Try the feature again.
If the error occurred when you were installing or upgrading EASYSHARE Software:
  1. Uninstall your current version of EASYSHARE Software:
    3. Select Remove.
    4. Follow the instructions to remove the software.
  2. Go to the Clear Utility for KODAK EASYSHARE Software at www.kodak.com/go/clear, then follow the instructions to run the utility.
  3. After restarting your computer, go to KODAK EASYSHARE Software at www.kodak.com/go/easysharesw, and install the latest version of software, free of charge.
Thank you for using Fixya!
Mar 23, 2011 | Computers & Internet
Error code 3825
Answer: Answer last updated:11-17-08 Error code resolutions are updated on a regular basis. If, after you search, you cannot find a resolution to your error, the instructions below can help you.
IMPORTANT: Print this page before continuing.
Search for a resolution to your specific error code:
  1. Go to KODAK EASYSHARE Software Support.
  2. In the box under Find Answers, type the complete error code (without spaces), then click Search. An example is 12x413x1304x
If you don't find information for your specific error, follow the instructions below:
    3. Select Remove.
    3. Click Change.
    4. Click Next.
Nov 03, 2010 | Office Equipment & Supplies
I Can't download and install google earth 5 on my laptop error code 0x80040905. It worked fine on on my pc. I have windows 7 on boyh.
  1. Click "Start" > "Settings > "Control Panel."
  2. Double-click "Add or Remove Programs."
  3. Scroll down to find "Google Earth" and click it.
  4. Click Remove, then Yes, then Finish. Please note, this may result in an error, which can be ignored.
  5. Download and run the Windows Installer CleanUp Utility at http://support.microsoft.com/kb/290301
  6. Uninstall your version of Google Earth by selecting it from the list and clicking "Remove". Please see below for a list of possible entries.
  7. Upgrade to the latest version from our download link at http://earth.google.com/download-earth.html
Sep 25, 2010 | Computers & Internet
Unexpected error.error code 11
Code 11
An attempt was made to load a program with an incorrect format.
Windows stopped responding while attempting to start this device, and therefore will never attempt to start this device again. (Code 11)
If you had install a device, Resolution
This error occurs when the computer stops responding during installation. It's a problem with Windows. To solve it, remove and reinstall the adapter.
Try upgrading the device drivers for this device.
Hope it helps.
Aug 12, 2010 | Computers & Internet
Why showing fatal errors during uninstalling java
go into Control Panel\Add/Remove Programs and scroll down to remove Java from my system. I click remove and it comes up with the window "Add or Remove Programs: Are you sure you want to remove Java(TM) 6 Update 13 from your computer".
I click yes and it says "Preparing to remove"
then configuring java.. and then come up with the window:"Fatal Error During Installation"
I've tried enabling logging.. it didn't work.. so that's all the info I can give, I have two HD's mounted.. if that helps.. I don't know. I tried using the install again.. it didn't work believe it or not s9.gif. Anyway please help
Mar 13, 2010 | ArcMedia JavaScript Source Code 3000 Pro...
Fatal error during installation
First u must make sure to close and exit all the applications that are using the resource of JDK.
Method 1: disable the auto load of JDK on machine start up from System Configuration Utility. Then reboot and try to uninstall again from the Add or Remove Programs.
Method 2: reinstall JDK and immediately uninstall it after the installation done. Or maybe u will found the uninstall function during the JDK setup.
Method 3: can try to use the cleaner software like CCleaner to uninstall the JDK application.
YBC (/\)
Jul 30, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Fatal error during java installation uninstall
go into Control PanelAdd/Remove Programs and scroll down to remove Java from my system. I click remove and it comes up with the window "Add or Remove Programs: Are you sure you want to remove Java(TM) 6 Update 13 from your computer".
Jul 01, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
An error occured during the installation of the
Step one: Uninstall the All-in-One software Even if the installation failed, some HP software components might have installed on the computer. Follow these steps to use the Windows Add or Remove Programs tool to uninstall the software.
  1. Disconnect the USB cable from the product.
  2. Click Start , and then click Control Panel .
  3. Click Add or Remove Programs . The Add or Remove Programs window opens.
  4. In the Currently installed programs list, select the following items if they are listed:
    • HP Officejet/Photosmart/PSC All-in-One software 9.0
    • HP Imaging device functions 9.0
    • HP Customer Participation program 9.0
    • HP Solution Center 9.0
    • HP Photosmart Essentials 9.0
    If the list of installed HP programs contains any version numbers less than 9.0, select the following items if they are listed:
    • HP Officejet/Photosmart/PSC All-in-One software XX (where XX represents a version number less than 9.0)
    • HP Imaging device functions XX
    • HP Customer Participation program XX
  5. Click Change/Remove , and then follow the on-screen instructions to uninstall the software.
    NOTE: If a prompt displays asking you to remove shared files, click No . Other programs that use these files might not work correctly if the files are deleted.
  6. Restart the computer when prompted to do so.
Apr 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
Yahoo messenger problem
you might have installed third-party plug-ins, audibles or emoticons on your yahoo messenger. these programs are automatically loaded everytime yahoo messenger starts. they work fine, not until you reinstall yahoo messenger or upgrade it to a newer version causing an internal error when they are loaded. first, remove/uninstall all these programs from the add/remove programs in the control panel, be very careful when doing so and be very sure of what you are removing. then uninstall yahoo messenger. if error still occurs during the uninstallation process, you haven't removed every program/emoticons/plugins connected to your yahoo messenger. when uninstallation is successful, restart your computer and then delete the yahoo messenger folder in the programs folder on your system hard drive. then you can reinstall yahoo messenger before adding/installing your emoticons or plug ins again.
Oct 01, 2008 | Electronics - Others
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
809 people viewed this question
David Payne
David Payne
