Question about Memorex MVD2042 DVD Player
Memorex DVD player
On the DVD player when you push the power button the red LED light just blinks and does not stay on steady. Nothing else in the whole dvd player works at all. Its like no power is even getting to the DVD player but the LED does blink. Does anybody have any information on how i can fix this or has recently had this happen to them?
  • 5 more comments
  • whoody Sep 27, 2008
    i have the same problem exept mine doesnt even blink
  • chris_32_tim Sep 29, 2008
    does anybody have a fix for this problem
    the led blinks and the power supply does'nt power up but just ticks
  • chris_32_tim Oct 08, 2008
    come on guys somebody knows how to fix this problem
  • jaimac Oct 13, 2008
    Same problem and there is some squeaky noise coming from the player. I rarely use the machine has been several months since I last used it.
  • tatamels Nov 21, 2008
    I have a similar problem. Mine doesn't blink, the standby red light turns on, but no other function works.
  • cmamo728 Nov 23, 2008
    the red led is on but it dont go on
See http://www.fixya.com/support/t197559-just_stopped_working. Look for the post "Best Solution" posted on Mar 10, 2008.
I'll bet you find the same problem. I fixed mine in less than 30 minutes for less than $2.
Posted on Dec 17, 2008
  • mr-diy Dec 17, 2008
    Forgot to mention - see my post for how to remove stuck disk.
  1. I have the same problem. I bought my Memorex October 5, 2008. Worked briefly 2x on weekend. Now, as of October 10, power won't go on and DVD disc is locked inside!!! My player does not click or blink!
Posted on Oct 20, 2008
Need code for Urc-3021 for memorex dvd player
I recommend using the auto-search function to find the code for your Memorex DVD player.
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your DVD:
  1. On the remote control, press DVD once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the DVD and slowly alternate between pressing POWER and DVD. Stop when the DVD turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 28, 2009 | One For All URC-3021 Remote Control
I need the code for dvd memorex. Thank you
The codes to control a Memorex dvd player are 221, 223, 225, 226, 227. They fall under the manufacturer name Tevion.
To program your remote follow these steps:
  1. Turn on your DVD.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the DVD button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the DVD and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Aug 22, 2009 | Innovage Jumbo Remote Control
Can't find the code to program RCA RTD207 dvd home theater system
try these codes:
  • 178
  • 184
  • 205
  • 218
  • 224
  • 228
here is another way to program the remote:
  1. turn the device you want to set
  2. aim the reomte control at the device and press and hold down the code search button for at least 3 seconds until the red led lights up solid red
  3. press the device button you wish to program tv, vcr, dvd,etc and the led light will blink once and then remain solid red
  4. press on/off slowly and repeatly until the device your trying to program shut off
  5. once this occurs press enter button to store the code and the led light eill turn off
thanks
tom
Jan 08, 2009 | RCA RTD207 System
Memorex DVD player won't work
the standby light switch is your on/off switch as well......
Nov 18, 2008 | Memorex MVD2042 DVD Player
Memorex DVD player problem
Hit the PSCAN switch on the back of the unit.
Aug 09, 2008 | Memorex MVD2042 DVD Player
Hi - trying to get universal remote to work on mvd2042 player
it might be the wrong code may i know model and brand
Aug 01, 2008 | Memorex MVD2042 DVD Player
Led light will not light
dvd citizen i need a code please
Jan 08, 2008 | One For All URC4220 Remote Control
Stand by light on but thats all
if it does nothing when you push the standby button to make it play the most common problem is the power standby sw is bad. do you know how to use a miltimeter if so test the voltage through the swithc when you press the button.
Oct 14, 2007 | Coby DVD-207 Portable DVD Player
NOTHING WORKS ON DVD PLAYER
My daughters had the same problem, try replacing C411 (I think that was the number on the board), its a 10V 1000uf capacitor in what appears to be the 5V power supply section toward the right rear of the main board, that fixed it. On hers the capacitor was swelled up on the end. I checked it out of the circuit and the DVM I used only indicated it had about 500uf capacity.
Sep 05, 2007 | Memorex MVD2042 DVD Player
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
Memorex MVD2042 DVD Player Logo
273 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
