I have a Hotpoint 1st edition 1200 washing machine and it won't spin. The belt is ok. Does the drum motor have brushes? Or can you suggest what the problem may be?
    Genius:
  • 1,122 Answers
Is it a top loader?alot of the time if a washer does'nt drain or spin the lid switch is bad,let me know more-miike
Posted on Sep 26, 2008
Drum doesnt turn
hi is the belt on if so 1st thing to check are the motor brushes good chance thats the proplem
Dec 27, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint washing machine barrel not turning all other functions OK. Motor, belt drive and bushes look ok new curcuit board replaced any Ideas? Model wma64
could be motor not rotating under pressure. When you say brushes have you removed them from motor to check them, also check they slide in and out thier holders ok, as they may be sticking
Feb 11, 2010 | Hotpoint WMA64 Front Load Washer
I have a hotpoint wma22. problem with it does not spin.The belt is ok .
+I would remove the motor and check the brushes for wear.
If they are less than 3 or 4mm long, thet need replacing.
If brushes o/k, then it is probably a control module fault.
I am of course assuming that the washer has drained the water out, or it will not spin.
Jan 12, 2010 | Hotpoint First Edition WMA22 Front Load...
Hotpoint WF220P has become very noisy during spin, especially at high revs. Can it be worn brushes or motor, or bearings? Otherwise all is OK.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Nov 02, 2009 | Hotpoint Aquarius WF220 Front Load Washer
My machine is making a noise as is it is spinning noise but drum will not spin around. any suggestions
Check to see if you can turn drum by hand, if you can, then prob could be belt, or motor not turning under load, check brushes in motor.
Please rate my solution.
thanks.
Aug 12, 2009 | Hotpoint WMA58 Front Load Washer
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Drum not turning
If you are certain that the motor was turning, then the only things that come to mind are that:
  1. The belt is stretched or worn-Replace as there is no adjustment.
  2. The drum is stalled, either because it has seized, or there is something stuck in the drum.
  3. The motor brushes are worn, and will not cope with load of drum, check brushes.
Try running it on fast spin without the belt on , if it spins o/k, then that would indicate the motor is o/k.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
Top Washing Machines Experts
