Question about HP Intel Pentium Dual Core Desktop Computer
D4996t desktop hangs on startup
Just recieved yesterday 9/25/08, HP refurbished, everything seems to run ok but it hangs on startup 1.5 -2 minutes on 'blue screen of death' except it had "hp invent' in the middle, and bottom left and right corners has this:
< I forget this one
then a blank screen shows for a minute then it starts.??
I haven't registered this comp yet
thanks Dave Manning
351 Lakeview Dr
Doyline, La 71023
318-987-2260
dmann436@yahoo.con
  • 158 Answers
I think there was a problem of virus, open in safe mode when its open then restore it for last known or when you start your computer press the F8 button then last known configuration if your porblem doesnt solve then reinstalled your windows
Posted on Sep 26, 2008
Windows startup
Go to Run (either in your Start menu or by pressing the Windows key plus the R key) and type msconfig
Click on the Startup tab and uncheck everything (disable all button will do this quickly) then click ok and reboot. The next startup should be considerably quicker. I would also recommend running a virus scan with Malwarebytes free version. Also install CCleaner and run it. Also, go into Control Panel then Programs and Features, and uninstall anything that you are sure you dont need.
Mar 07, 2014 | HP Pavilion Slimline s5-1260 QW695AAABA...
Tip
System problem if Hangs at Startup
Instruction applicable for all Window XP system,
For Any Brand and Model PC, whether it is of DELL/HP or any brand ..
Applicable to Desktop PC as well as LAPTOP
If your system hangs about 5 or 10 minutes at Startup/Bootup
And if you can't access the Start button or the Taskbar, most oftenly one of the specific service (Background Intelligent Transfer) running in the background.
Microsoft generally gives a patch for this but usually not work for in most of the cases
So please try this method, it is almost easy with no harm to PC.
  1. Click on Start
  2. Open the Run window,
  3. Type msconfig, then click 'OK'.
  4. Go to the Services tab, find the 'Background Intelligent Transfer' service.
  5. Disable it, apply the changes & reboot.
Next time you reboot the PC it will show System Configuration Utility window, place a Tick Mark in check box and then OK. SO that it would not appear again.
Also one more thing you can do Go to MSCONFIG and in the Startup Tab
Disable the items which you think not necessary to come during startup.
THis will help you lot to reduce the time being taken in Startup.
Hope it will work for you.
With Best wishes Ellin Scott
on Oct 12, 2008 | Compaq Presario 5000 PC Desktop
Hp pavilion d4996t
If a power surge didn't fry the mobo or PS, this can work: Unplug the tower from the 110 outlet, wait a couple of minutes, then plug it in again. Also try that with the power strip; unplug.. press its reset button, plug it back in.
Nov 16, 2013 | Computers & Internet
My HP DC7600 - get noisey when starting to plau games
http://almico.com/speedfan452.exe
Download and install and run this. You may want to go to the settings tab in the program and change it from metric. Then you can see the temperatures of everything in your computer. You can then launch the game and see what the temps do. It is common for fans to speed up when the computer senses large demand on the processor and graphics cards.
Dec 11, 2017 | HP dc7600 Convertible Minitower PC Desktop
I keep getting a service hang report, it says HP CUE DeviceDiscovery failed upon startup. When I go to windows reports and solutions it says a minidump.MDMP error.
change the following services.
Click on the Start button, then type "services.msc" in the "run" dialog box and click OK.
in case of vista/win7 type it in "start & search" box(you can find it once you click on windows logo)....
Set as "Automatic" the startup type for:
-Windows Firewall
Set as "Manual" the startup type for:
-HP Network Devices Support
-HP CUE DeviceDiscovery Service
you can right click on the particular service and click on properties....then change the startup type....
this issue will fix for sure....
pls do rate if its found useful...
Apr 02, 2010 | HP Hewlett Packard Pavilion A6200N PC...
How can i get this hp digital archive to stop
go to START, click on RUN, type "msconfig" (without quotes) press ok. Click on the STARTUP tab then click on "disable all" click "apply" and OK
Restart the system, you should not get the pop up again
Aug 27, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Start up problem
Techguru2009: The startup fails to load because you have too many programs trying to start at the same time when you log on. To fix this problem you are going to sacrifice what programs you want to start up when you log on. first I asume you are using windows operating system. click the start button, click on run, type msconfig, press enter. Click on Startup tab. Uncheck the box for programs you do not want to start when you log on. Careful not to disable windows startup programs. Hope this helps.
Feb 26, 2009 | HP Business Desktop dc5700 - Intel Pentium...
System hangs at screensaver at dell desktop 745
well try this
- > disabling startup programmes but not un-installing : Start -> Run -> type msconfig & press enter -> select startup tab on the top -> click on disable all. Apply & OK... computer restarts...
then
-> delete prefetch : Start -> RUN -> type prefecth & press enter -> in the window select all and shift delete.
then try performing disk cleanup ...
Sep 26, 2008 | Dell OptiPlex GX520 PC Desktop
Solve my problem
1) go to the start panel and click run 2) then type msconfig into the run box to bring up the system configuration utility 3)on the far left there is a tab titled startup click on that to see everything that is launched at startup Field explanations Startup items- the process names command- the program name or location location- the registry location (irrelevant) 4) Locate the programs and uncheck them 5) click apply and it should not start at start up anymore
Aug 07, 2007 | HP Compaq nc6220 Notebook
HP Intel Pentium Dual Core Desktop Computer Logo
171 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
