Question about Lexmark C910 Printer
Lexmark C910 Paper Jam
Hi
We have a low page count Lexmark C910 that jams frequently (every 5 - 20 pages, we normally use A3, we have tried various paper stocks).
When this happens the paper is just starting out of the top tray and normally if I open the right-hand door I find the paper just starting out into that area. The paper is normal in perfect condition, I just have to full it through.
We have tried an update to the latest firmware upgrade.
We have had this printer from new, it has a very low page count as no-one has the patience to put up with the farce of using this 28ppm colour laser printer as all in all, it takes longer to print a 10 page print-job on this printer than a £49 inkjet.
I have tried Lexmark but they just fob me off.
What is worse, if I clear the jam (or mis-feed), the printer goes through a two minute pantomine as it starts up again.
Don't get me wrong, if this beast worked as advertised it would be fantastic.
Can anyone help, or does anyone want an otherwise mint C910 for spares at a reasonable price (less than 10,000 prints, 60%+ full toners).
Thanks
Jim
    New Friend:
    Problem Solver:
  • 16 Answers
Could just be feed rollers are not picking paper properly. If they are dirty or dried out.....paper isn't getting to the input sensor in the correct time. Try cleaning with at least 70% Isopropyl Alcohol. Other thing to check for is...make sure there is not a tiny piece of paper stuck in paper path that is blocking the page coming out of the tray. If a previous jam was removed.....a piece may have ripped off and is hidden somewhere.
Posted on Mar 20, 2017
Soulvisitor
  • 1113 Answers
SOURCE: paper keeps jamimg
Clean all the feed rollers with a slightly damp soft cloth and see what happens, ensure if applicable on your model that media/paper type is set to correct format for what you are printing ie card stock / heavy, then throw it in the bin after releasing ones frustration on it.
Posted on Dec 13, 2007
Ajkill
  • 2035 Answers
SOURCE: Lexmark E238 prints about two thirds of a page and stops
Please follow the instruction given in this link:
clear the paper jam as given in this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=37:1:0:512:0:0&framed=&docid=ENUS25568&relevance=1
Posted on Jun 01, 2008
yooperbud
  • 8637 Answers
SOURCE: Lexmark E238 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
SOURCE: paper does not feed into lexmark X5470 all in one printer
Rollers could be worn out. Also could be a problem with the paper sensor. Not sure what type of sensor this printer uses. Some just use a pressure switch, others use a light sensor.
Posted on May 18, 2009
SOURCE: Paper jam in my new Lexmark x2600 inkjet printer
I had the same problem with it jamming every time that I printed. I took it a part and found that a pencil had fallen into the bottom of the paper feed. I removed it and it works fine now.
Posted on Aug 17, 2009
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
What does the "heart beat" symbol/light mean?
I assume you mean the symbol that has a pair blackened circles and then a pulse up and then down below the starting line before returning to the starting line.
That is the paper jam symbol. If the continue light is on (steady) and the paper jam light is on, then you have a paper jam. Press Continue twice to see any secondary error message (this will show where the problem is).
See the manual for the list of the lights that show where the jam is occurring. Different groups of lights will be lit. The manual is available as a PDF at the bottom of this page: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN . An example: if the Continue, Toner Low and Paper Jam are all on, then the jam is in the fuser area under the print cartridge assembly. For a paper jam, even a small corner of torn paper could be in the mechanism.
In all cases, you should check the entire paper path. When you pull out any paper, grip it so that you can gently pull the sheet straight out. Remove all paper from the output tray. Then remove the paper tray if you are using it. Pull any paper from this area. Press down on the green duplex flap and remove any paper from there Reinsert the paper tray. Open the front door of the printer and remove the print cartridge assembly. Lift the green flap and remove any paper from the area. NOTE: the fuser and the fuser area may be hot. Open the rear exit door and remove any paper from that area. Use a flashlight to check for small pieces of paper that may be stuck. Once all the paper is removed, reinstall the print cartridge assembly and close all the doors. Press Continue to reset the printer.
The page that jammed may be reprinted.
I hope this helps.
(please note that frequent paper jams may be a sign of excess humidity in the paper. Put less paper in the tray at each refill and keep the remaining paper in a dry location. If the paper jam light is coming on when no paper jam is present, one or more of the paper jam sensors may be bad. Contact Lexmark for more information.)
Nov 30, 2010 | Lexmark E250dn Laser Printer
Paper jam when printing onto my greeting cards
Hasn there is a roller which help the page or card to move into printer which if use frequently get so smooth that the page is not printed out instead get jam try getting printer service and replacing with New Roller.. if you don't understand any thing regarding ... ask me
Jun 23, 2009 | HP DeskJet 6540 InkJet Printer
Everytime I tried to print the paper get jam
Make sure all surfaces are clean and your paper has static electricity removed. you can do this by fanning it over a grounded surface. Check the paper feed rollers to be sure they are clean and have no sticky areas. Be sure no to put too many pages in at a time. Try one page at at time first to test and see if all goes well then proceed to try several sheets, about 10 or 12.
May 03, 2009 | Lexmark X2600 InkJet Printer
Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Aug 20, 2008 | Lexmark E340 Laser Printer
PAPER JAM
Rotate tires. Pull out paper tray. Pull down on red low paper indicator at left bottom. Two rollers come down on axel near center. I pulled off the rubber tire like roller, then twisted the roller inside out and reinstalled it with the fresh side out.
If tires dry out again will probably buy new ones from ebay.
Jun 26, 2008 | Lexmark E232 Laser Printer
Bizhub c 250
What type of paper are you using?
What is the gsm?
What did the Technician say about the jamming?
Jun 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Lexmark C910 Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
