Question about Kodak EasyShare One Digital Camera
Memory card is protected
My camera displays that memorey card is protected and I am unable to take photos. What does this mean
  • Wesley Elsberry
    Wesley Elsberry May 11, 2010
    Are you using SD or SDHC memory? If you are using an SD or SDHC memory card: hold it up so the corner with the triangular cut is on the upper right. Along the left-hand side you should see a small sliding switch. It needs to be in the up position in order for you to write to the card. If it is in the down position, the card is considered locked and you may only read the data.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
How to delete pictures in camera memorey
Go into the menu options of the camera, select Format memory card, then confirm and press enter.
Jun 14, 2016 | Vivitar ViviCam 7500I Digital Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Camera says "unabled to format, please replace card"
Check the SD memory card R/W switch.
SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Oct 20, 2012 | HP Photosmart M447 Digital Camera
What does protected card mean when i try to take a picture
Most SD memory card have a tiny slide switch on the side of the card. If the slide swited is in the Lock position then the photos are protected and you cannot delete or add (take) photos to the SD memory card.
Jun 17, 2012 | Fuji FinePix J10 Digital Camera
Green light on back of camera is flashing and I cannot view my photos
Green light flashing means that the camera is reading the memory card. If it keeps on flashing and flashing means that the camera is trying to read the card and not able to. This means that there is something wrong with the card. You should stick your card into the computer and transfer all your data from the card on to the computer. after all your photos are safe on your computer, put your card back in to the camera. turn the camera on, press the menu button, navigate to the menu that looks like a wrench and in that menu select "Format Memory Card" this will erase and format the card to how it should be. after that, you should be able to view your photos normally. If that doesn't work your card may be faulty and you may have to purchase another memory card.
Note: the camera might not display photos that you downloaded from you computer on to the card, cameras often only display photos that you took with the camera.
Feb 28, 2011 | Nikon D60 Digital Camera
Canon IXUS 95 IS - camera is displaying "card locked". I am unable to delete pictures and take pictures. Also i am unable to delete the photos from my computer. I get an error saying that write...
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 07, 2010 | Cameras
I am unable to take photos with my samsung digimax s800 camera as the message 'CARD LOCKED' keeps coming up on screen. I have deleted loads of photos so the memory card is definitely not full. Any ideas?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 17, 2010 | Samsung Digimax S800 Digital Camera
Olympus camedia c-3040 zoom how to delete pic
Judging by your explanation, the photos are on your sd digital memory card rather than the internal memory.
Since you are unable to delete just those 15, it sounds like you might have accidentally enabled the "protect" function.
Get out your manual (or download a new one) and read about how to protect/unprotect photos, and also read about how to format your card in camera - something you should do on a VERY regular basis for the health of your memory card.
While you have the book out, read ALL of it - twice! You'll be amazed how much you'll learn.
Oct 03, 2009 | Olympus Camedia C-3040 Zoom Digital Camera
16G Memory Gets "Memory card Error Please Check Memory Card"
You may try to format the memory card and then try again. If needed, you can use a camera photo recovery tool to recover photos from memory card.
Card Recovery Software Free Download
Apr 10, 2009 | Panasonic DMC-TZ5 Digital Camera
Problem with deleting photo from memory card
If the image has not been "Protected" to prevent erasure it sounds like it has become corrupted on the card. Suggest you save all images you wish to keep to your computer then Format the card (Erases ALL images) in your Camera. Hope this solves the problem.
Apr 28, 2008 | Apex Digital Digitrex DSC-3000 Digital...
Kodak EasyShare One Digital Camera Logo
43 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
