Question about Ovens
Microwave oven noise
I bought a new micrwave oven (GE LVM1750) that makes a clicking noise when the power is turned on. The noise is coming from the magnetron area. I exchanged it for a second one have the same problem.
  • calclassicbo Sep 26, 2008
    I've already done that with no different result.
  • Anonymous Mar 15, 2014
    GE lvm1750 microwave fan excessively noisey
  • 4,472 Answers
Your only options are to contact GE and see if this sound is normal. You may want to exchange the unit for a different model or different brand. Then you may not have this issue. Does the microwave operate normally?
thanks,
Lee
Posted on Sep 26, 2008
    President:
  • 2,712 Answers
Take it back to the dealer and enquire if this is normal. If it isnt, then exchange it for another and check in the store itself, before you take it home. If it is normal, then you have nothing to worry about :)
Micrwave is not heating, table do not turn
There is a good posiblity that one of the door switches is bad.
Oct 11, 2014 | GE Profile JT965SFSS Electric Double Oven
Microwave Fan making strange noise not heating food properly or at all
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
wg
Sep 25, 2010 | GE JTP86SHSS Electric Double Oven
MICROWAVE IS NOT HEATING AND MAKES NOISE
heatman101
Mar 13, 2010 | GE JTP85 Electric Double Oven
GE MODEL#JTP85W0W MICROWAVE IS NOT HEATING AND MAKING NOISE
heatman101
I have a ge jkp86 electric oven the oven will not heat up .the microwave works and all displays work
First thing that comes to mind is to make sure you are getting the correct voltage to the oven, you need 220 / 240 volts, check your breakers, fuses ,etc.
It is possable for the microwave oven to operate even if the power supplied to the oven is only 110 volts, but that low of voltage is not enough to power up the ovens heating elements.
If all seems well there, then maybe the oven element has failed / shorted ?
Good luck !
Jan 27, 2010 | GE JKP86 Electric Double Oven
Microwave is not heating and making loud noise and smells like burning
heatman101
jkl
Jan 20, 2010 | GE JTP85 Electric Double Oven
Convection works but Microwave does not heat
heatman101
duid
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
try using a voltage stabiliser .it may just solve ur problem..
May 17, 2009 | GE Monogram® ZMC1095BFBB /...
Microwave will turn on but not heat
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Nov 26, 2007 | GE JTP85 Electric Double Oven
Ovens Logo
89 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
