Question about Goodman Heating & Cooling
Need line set size for goodman ck-36-1a - Goodman Heating & Cooling
    Scholar:
  • 121 Answers
If your running gas heat it's 5/8 3/8 tubing.If it's elec. heat it's 3/4 3/8 tubing. Etheirway 3/4 3/8 works for both. Use 6 wire for tstat from tstat to furnace or air handler, and you need is 2 wire from condensing unit [outside] to furnace or air handler or anything more than two.
Posted on Sep 26, 2008
Want to reinstall...split system heat pump and gas furnace both goodman
What is current refrigerant being used in the system being replaced? What are the sizes of the existing breakers for the Air Handler, and the outside unit? Do you plan on replacing cooper lines ? Use drain line already there?
o
Dec 05, 2015 | Goodman Heating & Cooling
Where on a car can i get information about tank capacity
the operators guide has it.
and varies by country.
and engine options
and other options.
why not just fill it up from empty, and guess.
if car is USA, is it?
and you know whats on the car, engine size and type. and if 2wd or 4wd and other things, SR 5 and other options.
the login to alldata.com
but for free, you can go to any seller of any tanks and see this.
on 91 they had 5 major option packages. SR5 with V6 too.
the base 4 banger shows 17 and 19 gallon here.
see it?
http://www.rockauto.com/catalog/raframecatalog.php?ck[mkt_US]=true&ck[mkt_EU]=true&ck[mkt_CA]=true&ck[mkt_MX]=false&ck[year_1994]=true&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=kmn2mr0latem2ta7d7s59vvgk2
spectra premium can be seen on line and checked for size.
Jan 21, 2014 | 1991 Toyota Pickup
What size units do i have 1 is model #ck130-1b the other ck 7541b thanks
ckl36ar36 is a 3 ton. If both came as a set it should be a three ton system.
Sep 03, 2010 | Goodman CKL36AR36 Air Conditioner
Goodman cpl-j42-1a a/c unit, fan on outside unit not working, inside there is cool (not cold) coming out of vent..
sounds like you have a bad fan motor in outdoor unit or a bad run capacitor ck cap first you can go 1 size larger than listed on motor data plate
Jun 10, 2010 | Goodman CKL42AR42 Air Conditioner
I HAVE A GOODMAN CK-36-1A AC AND THE FAN IS NOT WORKING. WAS TOLD TO REPLACE THE CONDENSER CAPACITOR AND IF THAT DID NOT WORK REPLACE THE THE CODENSER FAN MOTOR. THE COMPRESSOR COMES ON BUT SHUT DOWN WHEN...
Goodman unit you can use a 1/4 hp or 1/3 hp cond. fan motor but it does sound like a cap. Replace cap first. Its very easy to do just open up panel and replace the silver bullet with terminals out the top. It will say on the side what size it is like 40uf 5uf or something like that. Thats most likely your problem. Russ
Aug 14, 2009 | Heating & Cooling
Easy change out of A/H
This is a 4 ton a/h. Your only Goodman choice is model # aruf486016.
Size specs are 22 wide x 53 1/4 high x 24 depth.
ref. lines 7/8 and 3/8.
Any current Goodman will be these dimensions.
May 01, 2009 | Heating & Cooling
Need the cubic inches for the return air duct
For proper minimum opening you need to do duct calculation. This is not a typical math equation for the typical homeowner. And unfortunately alot of contractors do not take the time to calculate this.
If you insist on doing this yourself...... I would recommend the largest opening that a common filter will fit. probably 20" by 25". Going to big on a return air will never hurt. But going to small will.
20" x 25" will work safely 95% of the time. But... If you are running airconditioning that is 5 tons in size, you will need the design a return air system that will feed from BOTH sides of the furnace.
If you are just sizing the trunk line you should use a ductulator to calculate the minimum size. A good rule of thumb would be to size the "return air" trunk 1 - 1 1/2 times the size of the supply trunk line.
Mar 01, 2009 | Goodman GDS80904BNA Open Flame Heater
5 ton goodman ac unit
You MUST WEIGH IN THE NEW CHARGE OF R-22. There should be a label on the side of the a/c unit that states what the factory charge was. This is only a starting point. Once you have the factory charge in the system, then turn on the unit and allow it to stabilize (5 min) . Check pressure on low side and check teperature on low side pipe. Temperature of pipe should be 8 to 15 degrees above what the boiling point of the refrigerant is for the current pressure you are reading. If the temperature is more than 15 degrees, add R-22 in 4oz increments allowing 5min in between each time you add until you are in the "zone". When you do this, your head pressure needs to be 225-250. if you need to cover the coil or block the outdoor fan to do this then do it. Hook up the vacuum pump and start over
Jun 17, 2008 | Goodman Heating & Cooling
GOODMAN # ARUFO49 AIR HANDLER
MOST ALL GOODMAN ( UP TO 3 TONS)INTERNAL FILTERS ARE 22" x 22" X 1". YOU CAN GET THEM ON LINE AT www.filtera.com. ALWAYS TAKE A TAPE RULE AND OPEN THE BOTTOM FILTER DOOR AND MEASURE THE FILTER RACK. MAKE SURE YOU DO NOT HAVE A RETURN-AIR FILTER-GRILLE. LARGE WHOLE -HOUSE RETURN AIR VENT NEAR OR AT YOUR FURNACE, A/C AIR HANDLELER. Joe_Rex New Member of FixYA Retired HVAC&R contractor 45+ years exp.
Mar 07, 2007 | Goodman CLQ48AR49 Air Conditioner
Heating & Cooling Logo
150 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
