Question about Acer Aspire L100 PC Desktop
Possible overheating problem for Acer Aspire mini L100
I suspect that my Acer mini aspire L100 has some issues with overheating and in so doing the motherboard has possibly gone bad.
It will power on at times and at others does not. The cooling fans run when it is turned on but sometimes there is no light indicating that the unit is on. I am interested to know if I will first have to replace the motherboard and then learn how to fix the overheating problem. Can you help me???
  • fix4once Sep 29, 2008
    Thanx you all but at this point as I am no computer tech and feel that by me messing around in it I would actually do more damage that than good...Hence, I am going to allow the "real" techies locally run a full diagnostic on it and then take care of it that way if I can...If not I will go from there!!!
  • Anonymous Nov 13, 2008
    I have exactly the same symptoms; the Acer would take maybe 20-30 tries to start. So I removed the HDD, DVDROM drive, fan, heatsink, processor, RAM, and front panel to test the motherboard, and got the same symptoms. After reassembly, it won't start anymore, even after being switched on/off over 100 times.
    I've discovered quite a few forums mentioning similar problems linked to overheating.
    Now I'm trying to track down a new motherboard, and then to figure out a better cooling system. Speedfan helps, but then it runs like a vacuum cleaner!
    Problem Solver:
  • 4 Answers
Replace the thermal grease. My fan would get real loud and my system would just turn off. I replaced the thermal grease and it is quiet and doesn't shut off anymore. The thermal grease only costed 10 bucks.
Posted on Apr 20, 2009
    Scholar:
  • 76 Answers
I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
Posted on Sep 29, 2008
2 Suggested Answers
phone crazy
  • 32 Answers
SOURCE: Possible bad motherboard/overheating problem w/ Acer Aspire mini L100
not sure if this will help you, but try checking your power supply it might be going out.
Posted on Sep 27, 2008
Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
Hi
thank you for your query
Please can you try the following
1) go to www.devicedoctor.com
2) Download and install the device doctor software
3) Once installed open it up and click scan, it will then scan your PC for the best driver
4) Download the driver (entitled VGA driver) and install
5) Restart and see if this cured the issue
Regards
Shauqat
Jun 02, 2010 | Acer Aspire L100 PC Desktop
You asked me to clarify my issue with an Acer Aspire L100. My problem is, there is no video output from the system. It appears as if the onboard video has gone out. The unfortunate thing with this mini...
You do have 1 PCI slot in that system. So, you could purchase a video card and place in that slot. Since your video is on-board you'll need to disable in Control Panel - Device Manager. Good luck.
Jun 19, 2009 | Acer Aspire L100 PC Desktop
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
L100 overheating
In most of the cases the cooling radiator inside the computer is full of dust, clean it as well as the fanblades and things will improve.
Try to find a place nothing is blocking the inlet on the back and the outlets on top and in the front, open the part which covers the usb and other connections on the front.
Sep 30, 2008 | Acer Aspire L100 PC Desktop
You wont be able to replace the mother board as it is a propriatary Acer unit and is now obsolete.
In all honesty these machines are so poorly designed you would be better to write it off.
The 3 machines i had fail and managed to repair are all now dead again with different faults.
Sorry.
Nick
Sep 26, 2008 | Acer Aspire L100 PC Desktop
Where can I get a replacement motherboard for an Acer Aspire L-100 Mini Desktop
The board is proprietary and no similar size boards exist. Acer has such bad customer service (lied and mislead me for months, then demanded $500.00 just to look at it) that I have chosen to scrap the unit rather than try other possible sollutions (larger case with different board, cracked solder joint detection, etc.)
Jul 24, 2008 | Acer Aspire L100 PC Desktop
Aspire Motherboard... again..
No the Acer is no manufacture the board
Oct 16, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire Mini PC
Hi, you will be able to purchase a mini ATX format board by almost any manufacturer that will fit the acer case, the only problem you may hve is the PCI and Graphics cards will need to be low profile standards but these are also available if you are not planning on gaming then the on board graphics on most new boards will do all you ask of them.
Regards mistyman
Oct 14, 2007 | Acer Aspire L100 PC Desktop
Unwanted System Shut Down
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} ok guys this is the problem i work for Acer and basically if you own an aspire L100 then you have to be prepared to modify your little bad boy because of acers poor design and a crappy little fan the anything inside the case feels like its on holiday in the tropics what you have to do is side mount 2 extra fans with separate 12v supplies and your system will never overheat or die on you if you have any questions on how to do this just email me :-) me
Aug 10, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire L100 PC Desktop Logo
479 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
