Most mobile handsets have the feature of: A) while the phone is ringing, use the up & down volume buttons to alter loudness of the ring B) while ur talking on the phone, do the same to alter listening volumne.
Settings In this menu, you can adjust various phone settings. To reset some menu settings to their default values, select Restore factory set. Tone settings Select Menu > Settings > Tone settings and from the available options: Ringing tone-To set the tone for incoming calls Ringing volume-To set the volume level for the ringing and message alert tones. If you set Ringing volume to be level 2 or above, your phone rings with the ringing volume ascending from level 1 to the level you have set when there is an incoming call. Vibrating alert-To set the phone to vibrate when you receive a call or a text message Message alert tone-To set the tone to sound when you receive a text message Warning tones-To set the phone to sound tones, for example, when the battery is running out of power
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout. Hope that was helpful?
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft. 1 Press Setup. 2 Press 4, and then press 8. This displays the Basic Fax Setup menu and then selects Ring and Beep Volume. 3 Press to select one of the options: Soft, Loud, or Off. Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring tones. 4 Press OK.
Adjust the volume
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
tones.
4 Press OK.
(for land line) Behind the phone one volume adjusting button is there, medium & loud you have to select loud one,or cell phone first go to menu then setting, then tones then ringing volume you have to adjust volume maximum and save changes.
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
