Question about Kenmore Refrigerators
Wire diagram Hello, I had to remove the front cover housing of my refrigerator to access the water dispenser switch as some of the guide pins had broken off. I had disconnected the wire assembly (part #2180240) from the switch assemble (part #2180236 on the front cover I marked each wire as to where they are suppose to connected to. Unfortunately I used a magic marker and with all the handling of the wires it rubbed off. Is there a wiring diagram indicating which color of wire goes to which connection? Thank You, John Baesemann jbaesemann@prescottastronomyclub.org
I took care of the problem. The wire colors were by next to each post with the color of the wires on the front panel.
Posted on Sep 27, 2008
I have to replace the dispencer control panel (part#821074P) on Fisher Paykel e522b with water dispencer, how can i remove the front cover to get to the electronic circuit panel
Disconnect the refrigerator from the power supply.
Looking up at the dispenser, Push the 2 outer tabs upwards and gently pull the panel forward once the tabs release.
A small screwdriver or key may need to be used to dislodge the tabs from the housing.
Two locating pins on the base of the front panel hold the housing at the bottom.
NOTE: The housing cannot be removed, as wiring looms prevent its removal.
To refit new module, perform in the reverse order.
Oct 02, 2016 | Fisher and Paykel Refrigerators
I have an Admiral side by side fridge freezer model number GC2027HXKW and the water dispenser is not working. The ice is still being made but I cannot get any water to come out
Hello Rosemary:
Are you good with a multi-meter and tools?
You either have a bad contact switch or the mounting pins holding the switch are broken. This switch is behind the dispenser cover. On the bottom of the cover there are two slots for a flat head screw driver to pop the cover off. There are several plastic tabs on the cover sides and top that you must be careful not to break. If you have a plastic round piece where the water dispenses you will have to remove this. Squeeze at the top and the piece. There are tabs that will release. After you have removed the cover there is a touch pad control board - inspect for burn marks. You will need a small screw driver to pry the electrical connector free. Set the cover assembly aside. You will see a green control board. Ground yourself by touching something metal. Static will knock out a control board.
There are several screws holding the board. Remove the board. Know you can see these small contact switches. One on the left side for the ice dispenser and one on the left for the water dispenser. Inspect the housing upon which they are mounted on for broken pins. The contact switch easily slides off these pins.
So, either the control board, the contact switch or it's housing is broken.
Or, you have a bad water solenoid valve. This is located in the back lower left hand corner of your refrigerator. You need to un plug your refrigerator. Pull it out far enough were you can remove the bottom cover. There are 2 solenoid valves. The solenoid valve with the water line running up the back of your refrigerator is the ice maker solenoid, the other is your water dispenser valve. You need to take the wire connectors off the valve. Using a multi-meter check for continunity.
I am sorry I am not their to repair your unit,
Peter
Oct 26, 2014 | Refrigerators
Side by Side water dispenser would not stop
You will need to replace the switch. Here is the part to order.
To replace the switch:
Here are the basic instructions: " 1. Unplug the refrigerator power cord. 2. Remove the overflow grille from the housing. 3. Unsnap front cover at the bottom of the housing. (You'll need to insert the tip of a flat blade tool into the slots molded into the bottom edge of the facade and twist or pry out,you may want to use some type of pad to eliminate damage to the door panel). 4. Disconnect the front cover switch harness connector and set the cover aside. 5. Disconnect the power wire harness connector (BL/BK and W wires) 6. Disconnect the flapper door heater wire harness connector (if one is present). 7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart."
Oct 31, 2012 | Whirlpool Refrigerators
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore refrigerator
1. Remove the switch cap and unsnap the two (2) tabs at the bottom of the front cover from the
housing first. Pull the bottom out and lift and the front cover from the housing. (Fig. 27)
2. Remove the two (2) hex-head screws securing the metal control panel cover to the dispenser
housing. This will also free the control bracket from the housing although it will remain tethered
to the freezer door by the wiring harness. (Fig. 28)
3. Disconnect the wiring harness connectors from the terminals
on the switches and light fixture in the control bracket.
Removing the Dispenser Assembly
1. Do the previous three procedures.
2. Remove the eight (8) hex-head screws securing
the dispenser housing to the freezer door. (Fig. 29)
3. Carefully pull the housing from the door.
4. Pull the water supply tube from the top of the dispenser housing.
5. Pull the wiring harness leads from the dispenser housing.
6. Disconnect the wiring harness connectors to the electric
foil heater that should get you in there
Feb 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Sears Kenmore Refrig #363-9554710 (side by side) - Remove panel on left front to access funnel guard
You will need to unplug the fridge or unplug the wires going to the dispenser from behind the grill at the bottom of the fridge.
Pop off the front cover over the switches and pop off the soft button cover that you mash to activate the dispenser.
You will see the screws that hold the dispenser assembely to the housing. remove them and the unit will slide toward you.
Post back if you need more help, I may have forgotten a step somewhere.
Oct 30, 2007 | Refrigerators
Water dispenser keeps running
Allen, one of two things here. The dispenser target switch has gone bad or the actuator arm is not releasing the switch. Remove the front cover by using a small screw driver to unlock the tabs at the bottom. Slide the panel down and out. Disconnect the wire harness. Remove the 4 phillip screws in the door dispenser housing. Slide the housing out and disconnect the target switch and light connectors. Now you can spread out the locking tabs and examine the switch. If this all checks good, then the board is the problem...Catriver...post back.
Dec 11, 2006 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
185 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
