Question about Crosley CDE6000 Electric Dryer
Dryer doing nothing
My electric Crosley Dryer does nothing. It's about 9 years old. The light inside isn't even working. I have tested the outlet and am getting power to the wall. Tested continuity of the plug and it has continuity. Tested the little round thing on top of the drum that has wires going to each end of it. Not sure what it is but I took the wires off it and it still had continuity. What is wrong with my dryer?
  • Crosley Master
  • 8,220 Answers
The fuse mounts on side of the heater. Its little clip is held to the side of the heater chamber by the same screw which holds the heater element down. It has 2 white wires going to it. Clean out the dryer and check for blocked vent and loose blower wheel. good luck Kimosabe.To access the heater pop the top:
dryer doing nothing - eaf511e.jpgthe heater is on the rear bulkhead, remove the front and inspect the filter area and blower assembly.
Posted on Jan 13, 2009
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
Son Threw in a VERY Wet Baseball Uniform - Dryer Now Not Working
ok check the fuse inside the unit! that is attached in the wire you can see the fuse there! if blown replace a new one! then observe the unit!
Oct 03, 2007 | GE Profile Harmony DPGT750EC Electric...
My Crosley dryer is not heating. I tested most of the parts for continuity after removing the back panel. One of the thermostats had 4 posts. Is the continuity supposed to be tested on opposite posts and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Crosley Dryers
Dryer was working fine until I turned off the breaker to work on an electrical outlet on the same circuit. When I was done I turned on the breaker all other outlets worked, I went to use the dryer and...
Hello Steve,
I am a bit confused because the model you selected is for a electric dryer which should have a dedicated outlet/breaker only for the dryer
I am going to assume it's a gas dryer and the trouble is with the outlet,to verify this plug a know working object into the outlet and see if it works
Even if the part in the dryer part that cuts the circuit to the motor if it's bad(thermal fuse) has no bearing on the drum light and that should work if power to dryer
Gene
Jul 29, 2011 | Estate TEDS840JQ Electric Dryer
My dryer want come on
Hunt for reasons why the dryer might overheat with the numero uno problena being a stripped blower wheel:
Wheres the fuse? Next to the heater:
Clean er up and party on
My tip: plain Jane Crosley dryer
Jun 26, 2011 | Crosley Dryers
Dryer is about 5 years old. Has begun to squeak loudly when clothes begin to spin
Are you comfortable taking the dyer apart? There are just a few simple screws to remove. It sounds like a bad blower wheel. If you follow the link you should be able to trouble shoot the issue.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info
Mar 01, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer doesnt work
I am an authorized crosley repair man. The fuse mounts on the rear wall on the right hand side of the heater element. When it blows the problem is usually a ball of lint in the filter housing or a bad blower wheel.ba7d2fe.jpgThe kit comes with 2 fuses. One for gas and one for electric dryres. Use the fuse with the same color dot as your old one. DEAD DRYER
Apr 12, 2009 | Crosley CDE6000 Electric Dryer
Dryer won't start
check door switch..onthejob
Jan 27, 2009 | Crosley CDE6000 Electric Dryer
Control Button Issues
My two year old unit would not do anything, but lights on. Then they would go off, and nothing but opening the door would get them on again. Replaced electronic panel in Feb. 2008, under warranty, still cost $80. Worked until first of June, 2008. Ordered a new panel. Repairman suggested that the wall outlet may be defective, even though the lights were on. The Unit also would have the lights come on by themselves. Outlet replaced, dryer worked fine. We still replaced the panel board, as repairman was not sure exactly what was the problem. I was told that the panel costs about $300.
Jun 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Crosley CDE6000 Electric Dryer Logo
97 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
