Question about Garden
Ryobi gas trimmer cord dont want to retract
How can i get the cord to retract
  • 50 Answers
The rewind mechanism is not functioning. It consists of a ratchet and spring. Examine and replace the defective part.
Posted on Feb 09, 2009
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
I have a Ryobi Expand-It 2 Cycle 26cc Trimmer , and when i attacthed the pole trimmer and tried to start it the pull cord won't retract.. do you know how to fix this? i can't get the cover off
the ryobi expand-it is just a power head ( motor ) that you can attach any ryobi or like attachment to
There is no reason why attaching a pole trimmer would affect the recoil of the starter rope as it just slides onto the drive at the end of the shaft
the fix will require the removal of the cover and the tool will be in a selection of bits that you can get from a good tool shop or auto parts shop
from memory it is a 6 point star around 3mm in size
the failure to recoil is normally a broken coil spring
Oct 30, 2017 | Garden
I have a Ryobi gas click it system. Have been
You didn't list the model but those little rewinds are typically built very similarly.
It may sound a little crazy but it works, take the unit to a power washer such as a car wash and blow out the gook in the rewind with lots of hot soapy water and then rinse. Then using a probe or small screwdriver get the rewind unstuck. If it retracts you’re good to go if not let me know as you may have a broken piece in there
Jun 04, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Trying to replace pull cord on ryobi cs30. How do
how do I repair/replace the pull cord on my Ryobi CS30?
May 22, 2010 | Ryobi Garden
How to pretension starter cord on ryobi whipper snipper
Remove the housing and pull the cord partly out. Then rewind the rest. Check to see if it retracts properly. Good Luck!
Dec 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi rlt30ces trimmer
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Oct 24, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi Line trimmer
you have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Jul 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
144 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
