Question about Frigidaire HV2736B Kitchen Hood
Kitchen Hood I am having trouble cleaning my downdraft hood...I am able to remove filters and clean but there seems to be grease build on the hood as well....The smell is really bad but I can't get down in the hood to clean.  Is there anyway to remove the hood in order to clean it better?? Thanks
  • 1 more comment
  • Anonymous Mar 16, 2014
    how do i remove the grates to get to the filter, and clean them all?
  • Anonymous Mar 22, 2014
    The readout telling me to clean the vent reads "C". I have cleaned the vent, but how do I make the "C" go away?
  • Anonymous Mar 24, 2014
    How do I clean the hood filters
    Novelist:
  • 171 Answers
Hi absimp,
I'm Harvey the Master Plumber.
Your question is: You are having trouble cleaning your downdraft hood...you are able to remove filters and clean but there seems to be grease build on the hood as well....The smell is really bad but you can't get down in the hood to clean. Is there anyway to remove the hood in order to clean it better??
The short answer is; not really. But don't be dicouraged yet, you shouldn't have to . There is a brush on a long handle that looks like the kind of brush you would use to wash a glass. I wrap the brush part with a small cloth that is wet with cleaner and just use from above rinsing the cloth as nessessary. If you have trouble finding a brush long enough just go to a plumbing supply and buy a brush made for cleaning the soot out of a boiler. If they know your problem they weill be happy to help.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
There is a cloth inside betwen the fan and the intake grill is it supposed to be there and if so does it need changing or cleaning it seems to be made of a composite material. we inherited the hood so are...
Some range hoods do contain a light filter material to prevent grease entering the fan. It can (and should be) cleaned regularly by hand in warm soapy water. Allow to dry and replace.
Mar 10, 2010 | Fagor 5CFB-48 X Stainless Steel Kitchen...
I am trying to remove the filter from a tappan range hood model HD1442I I see clips on each side of the filter but they don't want to move.
They are more than likely stuck from grease take a butter knife and slid it between the hood and the screen and break the grease seal all around the screen then try removing it by pulling on the tabs at the same time in one direction away from the frame it should come out. You can go to Wal Mart and buy Super clean to clean the grease out of it and the hood as well. Be sure to wear rubber gloves when using the super clean, it's in the automotive section if yo have a spray bottle you can buy the gallon jug it's like $7.00 for a gallon and $4.99 for 10 oz. spray bottle and I use it on everything cars stoves washing machines and any appliance that needs cleaned it is a very powerful cleaner. Hope this helps, if this does not do the trick let me know and I will give ya some more advice but pretty sure it's just the spattered grease holding it in place. Hope this helps and thanks for using fix-ya.
Jan 19, 2010 | Tappan TEF242 Electric Kitchen Range
The exhaust hood cannot **** out the smoke
Please check that the filters are clean. If they are old then replace with new ones.
Oct 12, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Sep 05, 2009 | Thermador HNW48YS Stainless Steel Kitchen...
Want to use without outside vent
sometimes rangemaster hoods have a filter system. check with them if your model does this. nuber for tech help by them on internet.
Mar 13, 2009 | Rangemaster Kitchen Hood
Filters for the Kenmore Downdraft Blower
CAN YOU PLEASE GIVE ME THE RIGHT CUTOUT FOR THIS DOWNDRAFT
Nov 13, 2006 | Kenmore 59940 Kitchen Hood
Frigidaire HV2736B Kitchen Hood Logo
287 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
