Freeing myn d drive
Keep on getting message that my D drive is full and i have to empty some space.cant seem to free up any space even after i delete.can you help me.tell me what i am doing wrong?
thank you irene
  • 75 Answers
Try chifting all the files u needed to another drive and format the D drive...
Posted on Sep 26, 2008
  • Manikandan Hariharan
    Manikandan Hariharan Sep 26, 2008
    sorry its not Chifting its shifting
Startup disk is full on Mac. How to clean it?
The OS X flashes the message 'Startup disk is almost full' when your OS drive (boot disk) is out of free spaces. Though it is not a major issue but its solution should be made asap.
You can make some quick free spaces through below tips/tricks
1) Empty Your Trash
2) Lighten your Download folder by removing unnecessary downloads
3) De-Clutter your Desktop
4) Empty Caches
5) Empty Logs
6) Lighten your Dashboard
7) Get rid of unwanted apps
Since your hard drive is large (1 TB), I recommend you use free clean up Mac software in order to get rid of garbage from your Macintosh HDD. You can free clean up your Mac with Stellar Speedup Mac tool.
Jun 26, 2015 | Apple MacBook Pro with 17" Display
Computer d drive full
Yes its always recommended to keep at least a minimum of 20% of total drive space as empty for lag free performance.
you will need to delete unwanted files on the drive to create some space else the computer would start running slow as the drive becomes full.
Please let me know if you have any other queries.
Sep 04, 2014 | Compaq Computers & Internet
I have a 16G USB flashdrive. I'm trying to save files from a video surveillence DVR and it was working fine until now. I started getting an error message saying the drive is full. i deleted engough...
When the drive is plugged in, empty the recycle bin or trash can on the computer. It may still being seeing used space because the files are technically still there. they don't really go away till you empty that recycle bin.
Jun 29, 2010 | PNY Attach? 16GB USB 2.0 Flash Drive
Getting a message\not enough disc space
check free disk space of all drive ,then transfer data from full drive to empty drive.
thanks
Feb 17, 2010 | Computers & Internet
Acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
I have a sony vaio laptop with seemingly two internal hardrives but one is very full and the other virtually empty but i don't seem to be able to move stuff across to balance it? I keep getting a message...
you probably only have one hard drive ,it may have two primary partitions ,look closely at the d drive,even though the pie graph says is empty ,the physicall size in mb,kb,gb,could be small,so basically your moving things on your full "c" drive to a small partition on your full "c"drive labeled" d "drive,if this is not the case,go to controll panel/system/,device manager ,and observe hard disk properties,if you have two hard drives,you will see two hard drives listed,usually the cd-rom takes the "d" drive position,and an extra hard drive will be your"E"drive,but a single drive with two primary partitions,forces the cd-rom to be "e"drive,this configuration often causes problems with cd/dvd-rom drives,just a side note ,in case it applies to your situation,hope this helps,post a comment if you need more help,aloha from maui todd0708
Oct 06, 2009 | Computers & Internet
My n 73 phone keeps showin memory full message,even though my inbox is empty and i have free space in my memory card.help.is it a virus
make sure your message memory is memory card. messga-option-setting-other-memory in use-memory card.
and try to free phone memory or better restore to factory setting. *#7370#
Aug 04, 2009 | Nokia N73 Cellular Phone
Sansa m230
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
Sep 07, 2008 | SanDisk Sansa m230 MP3 Player
Free Space problem
Running at that low of free space is a bad thing to begin with. You didn't specify if it's your primary drive, internal or external, or anythign, but I'm going to assume it's the one with Windows/Operating system on it.
Most modern operating systems need a few hundred megabytes, if not more, as "swap" or "temp" space. When your drive drops down to the levels you seem to be at you can get problems liek that which you mentioned, due to free space allocation for temp files, and whatnot.
Without more detail, like which operating system, type of HD, HD use, type of file you're saving and total space on the HD, I am afraid I can't help more.
For now I suggest deleting some old files, emptying your trash can/recycle bin, or simply restarting (if you don't do that much) to clear the cache.
Mar 17, 2008 | Kingston (SDCZ2-512-A10-KT)...
Free space on my external hdd
Check the file system on your My Book. FAT32 has a file size limit of 4GB. I ran into the same problem when I tried to copy over a 4.5GB file from my laptop with NTFS on it. The file would not copy.
Nov 27, 2007 | Computers & Internet
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
