Question about RCA F32650 32" TV
RCA 37" with Xbox hook up.
The problem I'm having is the top of the screen has a really bright line about 1 inch thick and the bottom of the screen is black about 2 inches thick. This doesn't happen all the time but it is happening now and the last time it went on for about a mont and quit. This time it is worse and the picture will jump and squeeze together. To get it to stop I unplug the tv and let it "cool off" and it is ok for about an hour. I have had the tv for 4 1/2 yrs and I have always bought RCAs. I have 2 more at home that are older and have never had problems with any of them. Thanks for any information on what the problem is or a solution. Stacey Stowe please email me at stacey68@charter.net
    Sergeant:
  • 359 Answers
Take in into a TV repair shop. DO NOT ATTEMPT to repair it yourself, TV tubes have a massive amount of electricity and could be fatal to a untrained person.
Posted on Sep 26, 2008
I have a 55 inch vizio lcd tv. it has 3 sets of 2 vertical lines going thru the tv and that are scribbly. i would like to get it fixed but not sure what part i need. thank you. Model no. M3d550sr
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD displays are similar, irrespective of its brand and screen size.
Dec 26, 2015 | Vizio Televison & Video
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Sep 05, 2007 | LG 42PX5D 42 in. Plasma HDTV
Tv help!
When you have the back off, look for the flyback (high voltage) transformer. This is the part that has the thick red wire protruding from its top which attaches to the top of the picture tube with a suction cup. On the flyback there are 2 controls, the bottom one is screen and the top one is focus. Turn the bottom control (screen) down (counterclockwise) until the white lines go away and the brightness looks normal. Then turn the top control (focus) until the picture is nice and sharp. If the F connector has been pulled out and the TV has RCA (red, white, yellow) jacks, use those jacks and set the TV to INPUT.
Aug 13, 2007 | Zenith A27A11D 27" TV
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Samsung 40" LCD HDTV
Sounds like a different source is the problem, start by eliminating each source hooked to the set, I have seen cable boxes do this, see if it does it on a dvd
Feb 16, 2007 | Samsung LN-R409D 40 in. LCD Television
RCA F32650 32" TV Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
