Question about Fuji Cameras
Takes perfect pictures then shows read error or memory card error & freezes
The camera works fine.then stops,freezes up and won't switch off unless battery removed. When battery replaced and card removed and replaced it works ok for a while.
  • 42 Answers
Format the memory card and then try!! if this doesn't work buy a new memory card ...
Posted on Sep 26, 2008
Why, when i take a picture and try to see it it comes up with a picture error on my sp-600z camera
The manual says:
Problem with selected image
Use photo retouch software, etc. to view the image on a computer. If the image still cannot be viewed, the image file is corrupted.
But try this. Switch of the camera, remove the battery and memory card. Check if all contacts are clean and shiny. On the battery, on the memory card and in the camera. Then replace the battery and memory card and switch on.
I hope this solves the problem.
Jun 04, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
Camera takes pictures unless I put in the memory card then it won't
What type and size memory card? The C653 works with MMC and SD cards, 2GB or smaller. Even though SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Apr 15, 2013 | Kodak EasyShare C653 Digital Camera
My camera used to work just fine with my pc, now my pc won't find the camera when connected with the cord. I also can't delete pictures because the camera freezes up. I also get 'picture e
You should format the memory card, while in the camera. Find the built in utility. If the format fails (try a couple times first) then get a new memory card. Possibly this will help the conectivity issue too, if not try looking in the Disk Management section (Right click My Computer, Choose Manage) See if the camera, connected to pc, is showing there without a drive letter. Right click on it and assignn it a drive letter. Hope this helps.
Dec 07, 2012 | Polaroid i633 Digital Camera
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
While taking pictures my camera all of a sudden froze and said card error, tried putting memory card on computer but it won't read it have tried using recovery programs but it freezes them please help
If your memory card is 4GB or larger, AND if your computer is two or more years old, your computer's card reader might not be able to read the newer 4GB SDHC card. In that case, just purchase an inexpensive USB card reader from WMart, or Amazon (here's an example). Try a different card reader first to see if you can directly copy and paste the pictures from the card onto your hard drive. If the new card reader doesn't see the files, then try recovery software. Here's some freeware to try. If the software still doesn't see the card with the new card reader, you may next need to try the corrupted card procedures described at the bottom of this linked article.
Nov 26, 2011 | PNY 4GB Secure Digital High Capacity...
Sandisk micro SD "card error"
The five pics are being stored on the camera's internal memory. The card you used was formatted and used in your phone. It's a miracle it worked at all. You need to get a new card, format it in your new camera have fun.
Dec 28, 2009 | Olympus FE-46 Digital Camera
Kodak Easyshare CX7430 losses memory when shut off
I have the same camera and the same problem. Can't use SD cards anymore, only the obsolete Multimedia Cards that are extremedly hard to find on shops because SD cards are the substitute for them... hope you can find a Multimedia Card. At least mine works fine with them.
Jul 31, 2008 | Kodak EasyShare CX7430 Digital Camera
Kodak M853 error message
My first inclination was that maybe the lock on the side of the SD card was on but after you mentioned that it worked in your mom's camera, I don't think that's the case. You may want to check that though. There's a little switch on the side and just make sure that it's switched to the "unlock" side.
The only other thing would be to format the memory card. When you do that, you will lose all the pictures on it. So, if it happens to work in ***********'s camera, I would transfer the pictures you already have saved on there and copy them to a cd before formatting the memory card.
In order to format your memory card, press the menu button, then go into the setup menu. There should be a list of settings. Scroll down to the format option and choose to format the memory card.
I hope this helps :)
Jun 12, 2008 | Kodak EasyShare One Digital Camera
Camera display shows "memory card error".
I would give this software a try:
http://www.download.com/VirtualLab-Data-Recovery/3000-2248_4-10610841.html?cdlPid=10801131
and be more vigilant about backing up your pictures. Flash memory can corrupt at any time. Good Luck.
May 05, 2008 | Canon PowerShot A520 Digital Camera
Wont read sd card..screen shows card locked..card ok
There is a little slide switch on the side of the memory card. Good luck!
Jan 02, 2008 | Aiptek IS-DV2 Camcorder
Cameras Logo
80 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
