Question about Amana ABB1927DE Bottom Freezer Refrigerator
11 year old amana bottom freezer icemaker drips water when filling tray
1997 Amana bottom freezer refrig model BCE20TW icemaker is making ice, but when the tray fills, water drips into ice bucket melting all of the cubes together. Icemaker replaced 2001. Defrost terminator replaced 2004. I love this refrig, but it keeps having problems. I believe in fixing things not just buying new. Sears told me that refrigerators are not made to last past 10 years, but this one needed work after the first 4 years. Do I need to replace the icemaker again? I used to be able to access the parts schematic with part numbers on amana.com, but I guess they don't support this model anymore. Any advice would be much appreciated.
  • ffzcubpilot Dec 15, 2008
    I need to let you all know that the problem with the icemaker was a loose attachment to the wall of the freezer. If the i/m can be wiggled it's loose (which mine was). I just tightened the screws holding it to the wall and everything is fine now!!
  • Chicago321 Feb 11, 2009
    I have had the same problem and have replaced the icemaker several times. The liner in the tray deteriorates and (you may have noticed specs in your ice) causes the tray to leak. I have not been able to find someone who sells hjust the tray.
  • 85 Answers
As long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Posted on Dec 14, 2008
SOURCE:
My ice maker in my side by side refrig/freezer leaks water so that a solid block of ice is formed in the tray maker. This prevents dispensing of cubes. What can I do?.
The cause of that is the water inlet valve is not fully closing but instaed its staying open a little and seeping water through it all the time which is dripping into the storage bin for the icemaker and freezing all the ice into one huge block. To repair that the water inlet valve on the back of the ref. where the house water supply line attaches to would need to be replaced.
GENE
Sep 22, 2011 | Amana Refrigerators
Thanks for your response Woodchuck 789- it is greatly appreciated. I tried checking the dual inlet valves as you suggested - switching electrical connectors and checking output, etc. The valves seem...
its hard to ck a valve that drips / and the ice maker may be over filling . if ice cubes are stuck to gether it is over filling . if driping . it may be a bad valve that does not shut off tight. I would replace the valve .. ****
Jan 07, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Too much water in amana bottom freezer ice maker
Try closing the valve partially on the incoming water to the icemaker. Close it to a trickle. Water is fed to the icemaker by a short timer. Too much water pressure means too much water. If this helps it but not solve it, get the spec sheet for the icemaker and adjust to make cubes smaller. This shortens the timer. If no joy, you may need to replace icemaker module.
Sep 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
NO ICE IN MY BOTTOMFREEZER AMANA REFRIGERATOR
If we both are on the correct subject then it is possible the water control valve on back of refrigerator is not working. If ice tray is dry then fill with water from a cup and let freeze. If the ice maker dumps the ice let me know and we will go from there. Sea Breeze
Apr 26, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
11 year old amana frig icemaker
you most likely have a short in the ice maker ..the ice should be ejected before the water is call for... you need a new ice make or if you can change the ice maker head let me know and I can help
Jun 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Freezer not cool enough and the Icemaker not working
Defrost the fridge freezer for 24 hrs and before turning on check for any water leaks. Turn back on if the cabinet pulls down to temp in 12hrs you probably have a defrost heater problem if it doesnt pull down at all it could be the fan or sensor fault. Either way you would be best to contact a suitable refrig engineer. Hope this helps. fishersofcambridge
Aug 06, 2007 | Amana SXD524VW Side by Side Refrigerator
Amana ice make problem
there is a screw adjustment that accounts for the variations in water pressure among various installations. Without one, problems such as yours will be widespread. Pry open the plastic cover over the icemaker. Look for a screw that has markings and/or arrows near it. I believe that turning the screw counterclockwise will decrease the amount of water allowed in. Experiment with each turn direction as necessary. You should see the amount of water fill with a flashlight. A proper fill should be about 3/4 to 7/8 filled. Never fill 100%. The cube ejectors may break then.
Jul 13, 2007 | Amana ABB1927DE Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
372 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
