SOURCE: tvalue 4 for windows will not print with a new printer
This is a work around as I have the same problem. If I change the default printer to something other then the HP printer, then select Page Setup, I can then select the HP without the program erroring out. You can even set the HP back to default and TValue will continue to work fine until you restart the computer.
TValue 4 is a 16 bit application which was last updated in 1997. By using a new printer you are mixing old and new technology and therin compatibility becomes an issue.
The only work around is to return to your old printer, or purchase the new version of TValue which is compatible with newer OS like Windows 7.
Recently got a new computer but can't run TV4? Where can I get an upgrade so I can run in Vista???
