Question about DeLonghi Heating & Cooling
I Have oil filled heater that has been sitting in the garage for three years and I lost any instructions were with it been with it,is there anything special I need to know bwfore I plug it in. Thanks
    Scholar:
  • 121 Answers
I take it that what you have is a space heater. Which would mean yes there are somethings you will want to check after three years of storage. First of all would be the oil buner which is ignited by a step up transformer located in the rear of the heater. There is a box on top of the blower that you can open you will see two electrodes and two tabs off the transformer. Sanded those with a light peice of sand paper. That will make sure your firing system has good contact, other than that you can't tell until you fire it up. That amount of time in storage could have gummed up the feul pump or anything else mechincal or elec..
Posted on Sep 26, 2008
I need instruction manual for HZ-705 oil heater lost manual when moving, can I dowload.
follow the link:
http://www.2shared.com/document/HyzOEjtx/oil-filled-heaters.html
Nov 07, 2011 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
I have a Honeywell Oil filled heater, HZ 680 series. When both switches are turned on, they light up but there is no heat. Also, a funny smell then the switches automatically turn off. Is there anything...
These heaters last about three years,and are throw aways,unless you have some in the ole shed like I do.Checking the switches is the first thing to do,remove them to see if they are burned up on the other side where the connection is.If they are,that could be the smell,or the thermostat is melted down,and smelling,again,throw away,,or save it,and buy a new one,and you will have parts for when it goes out,if the switches are melted down,a compatible switch,if found,can be replaced in the heater,but something made the switches melt down,most likely a heating element in the tanks,non replacable.
Jan 05, 2011 | Honeywell HZ-680 Oil Filled Radiator...
Doesn't heat up as first bought three years ago.
Not unless it leaks oil on the floor. The oil has nothing to do with heating, your unit is actually an electric heater with oil added as "thermal ballast."
The first suspect is the plug that you plug into the wall. These sometimes overheat and electrical continuity is lost.
Solution: new plug from the hardware store. Cut off the old one and take it with you so you can get something very similar. Don't do anything if you're not comfortable with handyman-level electrical repairs.
Next suspect is the cord itself. These have a hard life on electric heaters.
After that you're inside the unit. First suspect is the thermostat, since it's the only moving part. A burned out heating element, or a burned wire connection, is possible, but not the first thing to look for.
Generally, this kind of heater often lasts for years and years--and often doesn't. Once you're past replacing the plug it's not unlikely that repair will cost more than a new heater.
I'm not shilling for Home Ripoff, but they have a $60 "baseboard" (type) heater with remote control that I'm looking at, I've read good reviews about it. However look closely, it's very long, and sticks out from the baseboard more than you might expect.
Mar 28, 2010 | Pelonis Heating & Cooling
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual that you need. Hope this helps. If you need anything else, let me know.
Nov 19, 2009 | Honeywell HZ-709 Oil Filled Radiator...
I need operation instructions for HZ 680
I happened to be sitting here with a manual looking for a retail price so I could price it for a yard sale on Sat. I could email a scan (It's not lenghty)
Jan 27, 2009 | Honeywell HZ-680 Oil Filled Radiator...
Loud ticking noise coming from motor and motor runs rough.
u didnt hurt anything,make sure u're using  multigrade motorcycle oil
Jan 21, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Instruction manual for hz705 honeywell oil heater
May I suggest contacting the manufacturer, Honeywell/Kaz direct at 800-332-1110.
Dec 24, 2008 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Warm up
if you go here you can download user manual..
enter brand and then model.
i used one last year and it ran continuous with no problems.
Sep 20, 2008 | DeLonghi 6507L Oil Filled Radiator Heater
Oil filled Heater will not turn on and heat.
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
Dec 03, 2005 | WeatherWorks CH3001 Oil Filled Radiator...
Heating & Cooling Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
