Question about Toto Aquia II Dual Flush Toilet
Unable to fit a toilet seat
The cistern to my toilet is behind a wall. and i cant fit a new seat
  • Anonymous Mar 28, 2014
    i want to fix toilet seat onto bowl
  • 43 Answers
Do you mean a water seat? like where you would install a water line? or a a seat you actually sit on?
Posted on Nov 16, 2008
    Novelist:
  • 171 Answers
Hi neenyc02.
I'm Harvey the Master Plumber.
Your problem is: The cistern to your toilet is behind a wall. and you can't fit a new seat
I'm having trouble visuallising your problem. For the average toilet there are only two sizes, round front and elongated. Compost and other special types are usually made to accept one or the other. If we're talking about a small marine tupe or such it would still install very much the same way. If you could upload some clear pictures of your problem it would help a great deal. In any case you will need access to the bolt holes (top & bottom).
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
I have a leak coming through my ceiling from the ensuite toilet above. It is an ideal standard wall hung with concealed cistern behind tiles. There is no obvious access panel. The tiled wall is flush.
The flush control panel normally comes off. You can then hopefully see inside. You won't be able to see much though as the cistern will be in the way...
Places to look for leaks are:
Soil pipe to pan
Cistern to flush pipe
Flush pipe to pan
Cistern overflow.
Apr 17, 2017 | Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
Client has a pan suite with this cistern. can u tell me which toilet seat would be used and what seat fixings would I ask for to replace broken seat bolts. Regards Anna
Contac any hardware store for these parts, bring the old parts with you so they can match them up, ACE or Orchard are good choices to go to.
Sep 26, 2016 | Home
How do i fix a leak from the cistern to the toilet bowl
There are bolts attaching the tank to the bowl check to see if they are correvtly tightened after you check to see if the gasket is properly seated.
Dec 25, 2014 | Home
Villeroy and boch toilet parts
attach 2X4s behind it to ensure its stable. I had same problem but used that wood to reinforce it (covered with hardy board & paint) and reattached it and wall is very strong and toilet does not move.
Apr 27, 2013 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
I have a toilet which is a one peice. The toilet seat has come loose and the bolts have dropped to the floor. I can not fit the seat back as the pieces that i would use to tighten the seat are on the floor...
In no case would you ever have to pull a toilet to get to seat bolts.My guess is if you take the tank lid off and look inside there youll see the bolts . If not you can buy another toilet seat with new bolts or just get the bolts to fit your seat and tighten it down.Forget about the old bolts unless they become a problem with the flushing of the toilet. Hope this helps
Jun 22, 2010 | Home
Cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
May 26, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
Elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Jan 31, 2009 | Kohler - Toilet - One-piece - Gabrielle -...
Toto Aquia II Dual Flush Toilet Logo
406 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
