Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Computer wont recognize external drive
Computer won't recognize drive. I was working in it yesterday, Today the computer won't recognize the drive. I get the emblem that shows I can remove it safely, but no drive on control panel. Product is the Simpletech Duo Pro Drive 1TB.
  • 5 more comments
  • phototom512 Oct 06, 2008
    I have the same problem with my computer not selecting the drive for the external drive.
    I need to reformat the simple drive
  • pillay123 Oct 20, 2008
    My computer also has the same problem. The drive isn't picked up, either on Windows XP or Linux.
    It also doesn't work on my laptop and even a friend's laptop running XP.
  • Anonymous Nov 30, 2008
    yes
  • danny77909 Dec 14, 2008
    i have a 320 GB same problem
  • george1234 Dec 14, 2008
    same problem here. I tried to detect it on a dell and a compaq. NG
  • wildpearl Dec 17, 2008
    Same problem - trying to store my music files for iTunes and my photos there - after about 9 months of working perfectly now it suddenly soesn't have anything inthe folders evern though the drive is still there. It shows the space being taken up and after a restart of the computer I see them there. When I use with iTunes sometimes it suddenly disappears.
  • Anonymous Jan 06, 2009
    el problema es que el drive no es compatible con la placa base
    Problem Solver:
  • 11 Answers
The simpletech 1tb drive's case has issues. I had the same problem. It actually quit while I was running a video off the drive. I replaced the case by removing the harddrive from the one it came in and installing it in another case and now it works again.
The first thing I would try is installing the drivers it came with, but failing that you will need to replace it's case.
It has 4 screws to remove, 2 under the silver warranty voiding tape and 2 visable on the bottom side. Remove them, then use a flat screwdrive to pop the case open (gently). Then remove the harddrive.
You will need a case with SATA data AND power cables for this to work.
Posted on Aug 02, 2009
Computer won't recognize external usb hard drive
Format drive NTFS sounds like its corrupt, use mini partition wizard...
may also need 3TB Unlocker from manufacturer of Hdd
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I have an Iomega external hard drive but my Acer Aspire One will not recognize the drive. It worked yesterday but today it is not recognizing the drive.
Hi
I guess that you have connected the external hard drive via a usb
have you tried plugging it into another usb
if it were not the case that it was working yesterday i would of said make sure the jumpers on the external hard drive are not set to master either take off completely or set to slave
hope this helps
Nov 18, 2010 | Acer Aspire One PC Notebook
Yesterday i was deleting some file. today my computer will not recognize external driver
You not mentioned what operating system is under your use. However we assumed that you are using XP. Start computer and press F8 key while booting before arrival of window logo. After few seconds you will be prompted for some options. Chose LAST KNOWN..... and press ENTER, you will done INSHALLAH.
Sep 23, 2010 | Acomdata (HD080UE5-72) (HD080UE572) 80 GB...
PNY 8GB Flash Drive - PC Will not recognize
Have you installed a scanner/another external USB drive since first trying your Flash drive? If so, try unplugging that and re-insert your Flash drive. I had this problem and a friend suggested this and it worked!
Oct 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
My compure wont recognize my external hard drive.
check if your external hdd connect to the pc.. cables is important..
Aug 24, 2009 | Computers & Internet
I/O Magic 320GB external hard drive making clicking noise
it happens when the hard is gone bad or can`t be recognised.you can try uninstalling the drive from device manager.you can check the hard drive case or can try the hard drive on some other computer.
Jul 08, 2009 | Computers & Internet
Western Digital Elements Drive Problem
check the drive on any other system.
may be last time you were using the drive and system carsh or improper shutdown this can cause the drive damage.
Also may be a virus format the disk and try it.
Jan 06, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Widnows doesnt recognize maybe corrupted? not sure
hey there - I should know whether it has an external power supply - Please give me the model. I think that it should be a hardware problem yet I need more inforamtion regarding your device and computer in general.
Nov 27, 2007 | Fantom Drives 120 GB Hard Drive
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
565 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
