Vaya a la pagina
https://www.weiderfitness.com
Blessing
[email protected]
cell+whatsApp: +50588611441
SOURCE: I have a Weider Platinum crossbow and the
This is a common problem with this machine, the wiring inside the back. Mine was broken too, it was just a loose wire, but the stupid wire is so inside a protective case, you have to take the whole machine apart to be able to reach it.
You'll need a technician to come to your home. Call Icon to get a reference.
SOURCE: I have a Weider Platinum XP800 Crossbow that will not start.
I had the same problem. Take off the black box at the base and check to see if any of the wires broke lose from the connectors, mine did. One pair of wires was alot shorter than the rest, so when the previous owner disassembled the crossbow he lifted the unit too far before disconnecting the wire connectors thus braking the two wires from the connector. Simply remove the remaining wire bits from the connector with something sharp (unplug machine from the wall). Then take the broken wires and push them down into the connector terminals with a butter knife. The terminals will cut through the wire insulation and make a contact with the wire. Problem solved.
SOURCE: weider platinum xp800 does not work
When turned on and increasing the weight, the digital numbers increase, but the weight doen't change.
SOURCE: WEIDER PLATINUM PLUS 1000, the
There is a wire that breaks that is attached to a limit switch that islocated inside the elbow of the Pivot arm. You need to extend the wire arerouted it to run on the outside of the pivot arm to avoid be nicked or pinchedby the moving parts. Hope this will help you. Good Luck.
SOURCE: need cable replacement for an older model weider
Here is the parts list for the weider 8225. It looks like there are two sizes of cable assembly
