Question about Tascam CC-222mkIII CD Player / Recorder
When turning on cd recorder it don't go past welcome, it freezes there, it a Tascam 222 cd recorder,What's wrong with it
When turning on the window reads "welcome" it dosen't go any further into boot up.I've had several tecs look into it and they don't find the answer
Try holding f8key be for it says windows and then either reboot or go to last go running go figuretion
Posted on Nov 09, 2011
SOURCE:
My tascam cc-222 read welcom want open
Is there a CD stuck in the unit? Did you push the tray to close? If non of the above you must remove and open the top to see what happened
Jul 08, 2011 | Tascam CC-222mkIII CD Player / Recorder
Tascam CC-222 not producing quality CD's Help
You need to verify that the signal going IN to the recorder is ok. There are a number of ways you can do this, the simplest and cheapest is to get another recording device you know works, that takes the same connectors, and test using that. Something like a cassette deck, or whatever a church member may have at home. If that works, you've determined that its the Tascam, if not, then you need to trace back to see where the signal failure is occurring.
Jun 18, 2009 | Tascam CC-222mkIII CD Player / Recorder
Problem with Tascam Cd-RW750. system error at start up after the "welcome". Then it opens the cd tray and does nothing else.
hello ,, how can i find optical pickup for TASCAM CD-RW 750 RECORDER ,,, what is the number of this optical please somebody help me ,, thanks ,ferr
Jun 07, 2009 | Tascam CD-RW750 CD Recorder
Im getting no sound when i used too get sound
Try new jacks,if you are always unplugging them,they can go bad,hope this works for you.
May 16, 2009 | Tascam CC-222mkIII CD Player / Recorder
I keep getting Disc read errors! when I put a CD-R in my Tascam CC-222. I thought the problem was with the discs so I bought more ... Sony CD-R. Still the same problem. Help
Either the player doesn't except this format which many don't read burnt discs. If it plays factory made discs, than it doesn't except burnt formats. If it doesn't read any discs, than the laser eye may need to be cleaned with rubbing alcohol and cotton swab
Apr 24, 2009 | Tascam CC-222mkIII CD Player / Recorder
How can I fix my tape player?
this unit has a variable tape speed adjustment ("pitch control"). Make sure this is set at the middle (neutral) position
Jan 11, 2009 | Tascam CC-222mkIII CD Player / Recorder
Don't know how to Pre-Master or Burn to CD, please help me!
Don Q -
This answer assumes you have the 2488 mkI and not the newer mkII because the process may differ slightly on the mkII.
To premaster you first have to set an out point for the end of your pre-master (the start point is always zero). Go to the 'Audio CD' menu item and choose 'pre-master' under that. You'll see the word 'mastering' appear in the top left of the screen to let you know you've entered mastering mode. Make sure you have the tracks unmuted that you want to mix into the pre-master and have all of your eq, panning, etc set the way you want. Then hit record and play. The pre-master records to a stereo pair of dedicated internal tracks. You can redo the premaster as many times as you like which will overwrite those internal premaster tracks. You can clone the premastered tracks to a stereo pair of tracks, export them as waves or burn them to a CDR.
fnawesomewes - You have to press record and play to record your premaster.
Dec 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam CC-222mkIII CD Player / Recorder Logo
199 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
