Question about Canon imageRUNNER 400S Copier
CANON 6050 B TO B ERROR
MANY TIMES WHILE GIVING ORDER FOR BACK TO BACK "PAPER MISFEED" ERROR COMES. ANY SOLUTION
Code E220 in canon image runner 550
Posted on May 04, 2009
    Problem Solver:
  • 3 Answers
The gear on back side of b to b tray got lot of lubricaion. it was removed by alcohol. gear slipping was the cause for it
Posted on Sep 27, 2008
I have a Panasonic Workio DP3030 showing error code J93 paper misfeed in ADF. I have followed the manual and there is no paper jammed but I can't get rid of the error message.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Nov 03, 2013 | Panasonic Workio DP-3030 Printer
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Nov 01, 2013 | Sharp AR-M205 Copier
KM6530 keyocera copier gives paper misfeed JAM50 after making copy.which paper sensor could be out of order?we have checked all sensor and paper path.
check the exit unit sensor. the flag sensor there does not come to home position after a copy has been exited.
May 31, 2011 | Kyocera Copier
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
MY PRINTER STOPPED PRINTING AND GIVES A ERROR MESSAGE THAT THERE IS A MISFEED. I CAN NOT SEE THE PAPER FROM THE FRONT OR TOP ARE THERE ANY OTHER SOURCES THAT I CAN CHECK TO CLEAR THE MISFEED, IF THERE IS...
You need to consult your manual for all the paper paths that you may have missed.
Check all paths and go out and buy paper path cleaner, follow the instructions on the package and completely clean out the paper paths.
This should loosen or remove the stuck paper and get the printer printing again.
Please write back results (good or bad)
Mar 16, 2010 | Ricoh Aficio SP C231N All-In-One Laser...
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
153 people viewed this question
old marine
old marine
