Question about Panasonic KX-TS3282B Corded Phone
Lights blinking and cant intercom
Hello, our lights on the right side of the phone have been blinking continuously and thus we cant click on our lines to choose which one to call out on, nor can we use the intercom feature. Any help would be greatly appreciated!
  • lennui40 Mar 24, 2009
    I've got the same thing. All the intercom buttons blink constantly and we can't use the intercom.
  • abchiropract Apr 10, 2009
    Ours is the same on one phone and we cannot use the second line...
5 Suggested Answers
SOURCE: Programming line
press program then 1 and select what u need
1 for intercom
2 for co and select co No also.
for the speed dial store 9 before ur No
ie 9+123456789
Posted on Apr 18, 2008
cnavarro
  • 2460 Answers
SOURCE: call waiting
Since the phone is basically stupid, it's hard to say. The 7731 has the capability of what you ask...if...the sytsem does.
When you find out what cabinet the 7731 is connected to, post back and you'll get the codes. In the meantime you might try looking in the book for Call Waiting C.O On a TAW-848 the code is *7311. On a TA-824 it's 7311#.
Carl
Posted on Sep 06, 2008
cnavarro
  • 2460 Answers
SOURCE: Panasonic Kxt 7731
What happens when you dial "9" into the intercom dial tone? Is that the line you wnat to auto select?
A lot depends on the system your phone is connected with. In a TA series on an idle phone, press PROGRAM 11 for no preference (what you have) 12 for Idle line (what you get when you dial 9) or 13 and a number from 1 to however many lines you have to select a specific line.
Those commands are followed by the STORE button and PROGRAM to end the programming.
Carl
Posted on May 28, 2010
  • 20 Answers
SOURCE: our phone seems to be stuck in the intercom mode.
try pushing the intercom button again
Posted on Jun 14, 2010
NEC DSX 22B intercom light won't stop blinking
A double-wink on the Intercom button indicates "Intercom Hold". Normally, lifting the handset and possibly pressing Intercom will take care of it. We had a phone for which that didn't work. In that case, use DSX System Administrator 3 to reset the station port. On the left side of the main window, click Reset Station Port under Utilities. Enter the extension number and click Start. It takes a few seconds and does not disturb other parts of the phone system. Hope this helps!
Aug 02, 2013 | NEC 1090020 DSX 22Button Display Phone...
I have a Panasonic Keyphone Model: KX-T7750, having problem with alert of intercom/incoming calls. No ring tone but with flash light and intercom light on. May I know how to fix this. Thank you!
Calls are signalled in two ways. First, check the Ringer switch on the left side of the phone. It's a 3 position switch OFF/LO/HI. If the outside lines are blinking the MESSAGE light, then the ringer is probably turned off. If your intercom calls are toning but not ringing, you may have the AUTO ANS light lit. Press it until it's off and intercom calls will either start ringing or send an audible tone.
If it tones, then you have a programming problem where intercom calls are set to tone instead of ring. That's corrected in system programming.
Carl
Apr 25, 2011 | Panasonic KX-T7730 Corded Phone
Mls12d to turn on local ringer
First of all, is it programmed to ring? From Ext 10 or 11 press FEATURE 00 LIC LIC RIC and dial the extension you want to look at programming. The line buttons will light up. They will be SOLID for RING, SLOW BLINK for DELAY RING, or FAST BLINK for No Ring. Just keep pushing each line button until you get what you need. When you're done, press FEATURE 00.
LIC is LEFT INTERCOM RIC is RIGHT INTERCOM button.
Easy enough :-)
Carl
May 17, 2010 | AT&T Lucent MLS-12D Phone
CANT GET INTERCOM TO WORK
Be sure you are pressing the correct extension key for the phone you are attempting to call. Just press 'intercom' and the key number (from the right side of the phone marked 1-16).
Feb 18, 2009 | RCA 25414RE3 Corded Phone
Intercom light stuck on and no dial tone on GE 4 line phone
You may need to assign an intercom ID for that unit by pushing one of the intercom buttons at the top.
Dec 05, 2008 | GE 2-9450C Corded Phone
Phone ringing.
On extension 10 or 11 press Feature 00
Left intercom, left intercom, right intercom
Enter your extension number
Press line buttons until its a fast blink and display say no ring
Feature 00
only transfered calls will ring
Nov 21, 2008 | AT&T Partner 18 Phone (315805B)
Speaker phone light continually blinks
The blinking light on the speaker button means the forward when busy is on. To cancel it- With the handset on-hook dial #12.
Then press your own station number. Then dial # again. The speaker button should stop flickering.
Note: If the SPK button continues to flicker, Forward all is activated. It is the same process as above but use #11 instead of #12
Feb 21, 2008 | Samsung Prostar 816 Phone
Phone does not ring or show caller ID
From extension 10 or 11.
Press feature 00
Press left intercom twice
Then right intercom once.
enter your extension number
You will see the lights blinking green on the phone, where your lines are. Touch them until they are solid green. If you want to program another extension, press the right intercom button again and enter the new extension number.
Once done, press feature 00 to exit programming.
As far as the caller ID, there is no way to turn it off on the Partner system. My guess is the provider isn't sending caller ID.
Jan 04, 2008 | Lucent PARTNER18 Corded Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Panasonic KX-TS3282B Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
