POLAROID TV HAS NO PICTURE
HI, I BROUGHT MY DAUGHTER A POLAROID MODEL # TLA 01511C. LAST NIGHT THE PICTURE WENT BUT WE STILL GET SOUND. I CALLED THE STORE BUT THEY NEVER SCANNED THE SERIAL #. POLAROID WONT TOUCH IT WITHOUT A RECIEPT. HOW CAN I FIX THIS MYSELF. I AM PRETTY GOOD WITH THESE THINGS. JUST NEED EXPLANATION.
THANKS
    Genius:
  • 1,139 Answers
Hello RAEQUINTERO,
The problem you described sounds like either your inverter or back-light has malfunctioned. There is a way to test this. Turn your TV set on and in a dark room shine a flashlight onto the screen and see if you can make out a faint image of a picture. If you can this means that the back-light or the inverter has malfunctioned. Now at this point I should tell you if either of these has failed you have to make sure to check if the back-light, inverter and LCD screen are not one unit, because if it is the screen with the inverter and back-light will cost as much as the entire TV. If the screen inverter and back-light are separate devices then you will only have to replace the defective part. These are the pieces of equipment and documentation that you will need to properly repair this problem:
1) The schematic for the TV try www.servicemanuals.com
2) A Multimeter To measure the voltage levels and bias voltages of the inverter and back-light inputs and outputs
3) Signal generator To establish a know good test signal for proper measurements
4) Oscilloscope To measure wave patterns from the Video output feed.
Use the schematic to show you what the voltages should be at different points on the back-light and the inverter. Use the multimeter to measure these bias voltages and voltage levels on the back-light and inverter pins and board connections. Use the signal generator connected to the F connector of the TV to establish a known good signal to the TV. Then use the oscilloscope to measure and view the video signal levels and the data stream that form the picture.
You may have to do a lot of removal of boards to get the the LCD back-light and inverter, however the schematic will help you with this (Remember to mark all cables for easy reinstallation).
This is the way to do this if you are going to attempt this yourself. If not please have a qualified TV repair-person give you an estimate of cost and have them repair the TV set.
I hope this helps
Thank you,
Shuttle83
Posted on Sep 26, 2008
No picture on tV
Yes,Ur LCD inverter board is dead.Replaced this board will get ur picture back.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Apr 25, 2010 | Polaroid TLA-01511C 15 in. LCD Television
My Polaroid TLA-01511C has sound but no picture...what do I do
Replaced the LCD inverter backlight board is dead.After U replaced this LCD inverter board.U will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board.It a long board shape.
Feb 21, 2010 | Polaroid TLA-01511C 15 in. LCD Television
Sound no picture Polaroid 15.4 TLA-01511c
If you take a good look at the screen when it goes dark can you make out anything maybe some bright scenes on the channel you were watching or if you press the menu key, you can see a very dim display, you might need the back light assembly or something related to it.
Jan 09, 2010 | Televison & Video
I have a Polaroid TLA-01511C 15 in. LCD Television that has no picture but does have sound. Solution #1 in this page says "a bad cap in the power board, the can like device will have a puffed up top from...
Radio Shack is your best bet. I replaced two 680uf 10v caps and one 1500uf 10v cap. It now works just like brand new. The caps I replaced had higher voltage values hopefully this will help prolong the life of them.
Nov 27, 2009 | Polaroid TLA-01511C 15 in. LCD Television
I have 3 Polaroid TLA-01511C 15 in. LCD Televisions that have no picture but does have sound. Is this a common problem with this model?
I replaced three capacitors on my power supply board and the unit started working again, There was two 680uf 10v caps and one 1500uf 10v cap bad.
Nov 20, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid TLA-04641C no sound
You should go into the menu SOUND section of your tv. Look for the TV Speaker choice option.
This will have to be turned on to get sound from the tv.
Feb 23, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Televison & Video Logo
254 people viewed this question
Top Televison & Video Experts
Electro Med Services...
