Question about Consew 226R-1
Consew 226 breaking needles
The machine started breaking needles. After taking out the plates to see the actions of the hook and needle, I can see that the hook is making contact with the needle, even grabbing the needle, pulling it in and thus breaking the needle. Is this a problem with the timing ?
  • hack4 Jan 23, 2009
    How do time this machine
  • 26 Answers
I posted an answer to this a couple days ago. If the hook's hitting the needle you need to move it away from the needle. There's a small screw in the bottom of the machine that holds the hook mechanism in place. You need to loosen the screw and gently tap the assembly away from the needle. The hook should just pick up the looped thread as the needle bar rises. You can go to www.consew.com and download a pdf file showing the parts of the machine, also an owners manual. You have to click on the 224 machine. The manual's the same for 224, 225, 226. Or you can click on the 226R-3 - that's the same, too.
Posted on Aug 31, 2009
My consew 226r1 shuttle hook tip broke off. How do I remove and replace this part? Thanks y'all!
Tilt the machine up. There's a screw holding the hook in. Loosen, remove base plates, lift the hook out and replace. Don't move any thing else or you'll have to reset timing.
Jun 14, 2014 | Consew 226R-1
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I bought a consew 230 industrial machine, but when I try to sew on it the needle breaks. What do I need to check, the threading, needle or what?
make sure the needle is inserted correctly
check the needle clamp screw to make sure it's tight
the needle is to fine for the fabric being used
also make sure under the needle plate there is no lint
also in bobbin area
also check the tension
Nov 26, 2010 | Consew 206RB
I recently moved and can't find the belt to my Consew 226. Having problems finding a replacement. Can you help!
Go to www.consew.com and download the parts list for the 224 Consew. It's the same as the 226 for parts. Or, go to www.diamondneedle.com. They have nearly every part you're likely to need. I got bobbin case screws, a hook, some metal reusable bobbins, and some needles, all at very reasonable prices.
Oct 16, 2009 | Consew 226R-1
Thread skips
Well, Hello Kim. Once the Needle for the machine is changed, there is a good possibility of the timing of the stitches being altered and hence the problem.
  •  Firstly, make sure that the needle is in correctly with the scarf of the needle towards the hook. Take the needle plate off and the presser foot off.
  • Turn the handwheel towards you until the needle is in the lowest position, and on the needle bar you will see two lines somewhere near where the needle bar enters the machine.
  • When the needle is in the lowest position, the top line of the two lines should be flush with the body of the machine.
Jan 05, 2009 | Consew 206RB
Loose top stitch when in reverse 206 RB4 Consew
Do you know how to check the timing of your machine? It sounds like a timing problem to me. If you don't know how to check the timing:
take the side plate off, take the needle plate off, take the presser foot off, and put a new needle in the machine. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line. Then, turn the handwheel toward you until the top line is where the bottom line was. At this point, the tip of the hook should be directly in the scarf of the needle.
Oct 19, 2008 | Consew 206RB
Consew 226 r sewing machine
  • Take the side plate off and also take the needle plate off
  • Take the presser foot off, and put a new needle in the machine.
  • Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
  • Then, turn the handwheel toward you until the top line is where the bottom line was. Note: At this point, the tip of the hook should be directly in the scarf of the needle.
Jul 22, 2008 | Consew 206RB
Breaking thread
1. Make sure you are using the correct needle and thread for type of fabric and it is installed correctly. Make sure bobbin is threaded evenly. 2. Tread path - make sure the machine is correctly threaded. Then, with your finger, feel for burrs, nicks or roughness on any metal parts that contact the thread. Open the slide plate, remove the bobbin and inspect the bobbin case and hook. Remove the needle plate and examine the needle hole. Sand any rough areas with fine emery paper and blow away grit. If burrs or nicks remain on the needle, presser foot, needle plate or bobbin case, replace them with exact replacement parts, if they remain on the thread guides, take-up lever, bobbin hook or tension regulator, take the machine for professional service. 3. Loosen thread tension by adjusting tension dial. 4. Clean feed dog, bobbin case, and tension discs. Unplug the machine. Use a small, stiff brush to wipe dirt and lint off the machine head and the needle bar area. Raise the presser foot and the needle to the highest position, open slide plate and remove the bobbin and needle plate. brush away dirt and lint from the feed dogs and bobbin case and remove any tangled thread with your fingers. Use a soft cloth to clean between the tension disc on the tension regulator. 5. Also check tension on presser foot
Dec 31, 2007 | Consew 206RB
Consew 226R-1 Logo
632 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
