Question about Dirt Devil Vacuums
I just purchased a Dirt Devil machine on Monday, I finally got it put together today and the brushes are not moving, dust is swirling around but no brush movement, I have changed all the nap settings, nothing, I am having company tomorrow and I threw my other vacuum cleaner away, HELP ME. Thank you.
  • 37 Answers
Sounds like you may not have the belt attached or it is broke.
Posted on Sep 27, 2008
How do I get to the belt on my dirt devil
On the bottom of the dirt devil have to remove cover plate with screws and replace belt on motor
Apr 20, 2015 | Dirt Devil Featherlite Bagless Vacuum...
How to clean/lubricate bearings on Dirt Devil motor?
If you know some one with compressed air blow out all dirt particles best as possible then get a 3 in 1 oil or sewing machine oil drip along the motor shaft and turn by hand you will be able to free the difference once lubricated it should only take a few drops per side . let set for awhile and repeat . then put her together and see if motor speed returns to normal . also check turbine wheel for slipping on shaft.
May 01, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
Replaces the belt on dirt devil dynamite pluse model put everything back together started it and it burt the new belt up that fast. I put it around the beater brush and the metal bar I thought it should go...
The metal bar you put it around if the bar itself does not spin it is going to burn the belt up. Every thing that the belt is supposed to go around has to turn or the belt will rub on the piece not moving and brake.
Mar 18, 2011 | Vacuums
When machine is running the brush does not turn
You need a new belt. In order to change it, turn the machine compleatly upside down and place the head on a counter, handle on the floor.
There is a L shaped base plate to remove that has 5 screws in. Once the base plate is off, you see the brush roller and a silver shaft directly back from where the belt would ride. Remove the brush roller, place the new belt, Dirt Devil Style 5 ( see link below ) on to the shaft. Then insert the brush roller, so the belt is on the raised carved out section of the brush roller. Grab the brush roller at each end and stretch it till you are able to put the brush roller back into the base. Turn the brush roller backwards 3 compleat turns and the same forward to seat the belt.
Replace the base plate and you're done.
Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001 - Free Shipping Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001
Cost $ 8.00
Apr 28, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Got Dirt Devil Featherlite,keeps burning the belt out immediately and there is only one way to put the belt on...have put on 4 new belts.....what up?
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Not sucking up dirt in upright position
if there is dust flyin around the vacuum u might try lookin for clogs on the bottom where the beater brush pushes the dirt in and maybe where the dirt goes into bag ive used wire clothes hangers to free em up works..hope this helps
Dec 06, 2008 | Dirt Devil Vacuums
I have a Dirt Devil Swivel Glide Vac with a broken belt. I have purchased the correct belt(#4).The bottom is off and I cannot tell where the belt connects to. Please help. Jann
it connects to the left side with the little metal rod sticking out.then connect to the wooden roller. in the space without the brush on it. roll the wooden piece to check if everything moves. then put back together.
Aug 27, 2008 | Dirt Devil Vacuums
DIRT DEVIL MADEL 08245 BRUSE DOSEN'T ROTATE
I had the same problem and fixed it to where it would work OK, althought not 100%. 1. Disconnect the hose that goes to the roller brush area. 2. Press the button right below the power switch while sliding the handle what ever direction it will go to release it from the body of the vac. 3. Remove 3 screws from the handle halves. 4. Remove 2 screws from a keyed black plastic piece that hold the handle halves together. 5. Carefully separate the handles halves from the clear plastic piece in the center that allows you to view the brush and belt. 6. If the belt is broken or missing, replace it and reassemble, if the belt is OK, remove the roller and test if the bearings spin freely. 7. If they don't, then remove the clip or clips of each end that hold the bearing(s) in place. (Work in a controlled environment so that when the little clip goes flying you'll be able to locate it without moving the refridgerator.) 8. Clean the back side of the bearing of hair, dust and dirt. (used compressed air if you have it) 9. Reassemble the bearing(s) you removed and cleaned on each end of the roller. I used a spritz of teflon dry lube spray on each when I put them back together. 10. Disassemble the air motor bearing from the shaft on the end that does not have the belt gear. Be careful not to lose the flat thrust bearing/washer at the bottom of the bearing housing. Clean, lube and reassemble. 11. Since I felt I couldn't remove the belt gear from the shaft (to get at the bearing), without damaging it, I worked at cutting the hairs and threads wound around the shaft. I used a single edge razor blade to painstakingly cut and remove what I could, then lubed and reassembled air motor. 12. I then reassembled everything and tried it. IT WORKED. The still sluggish bearing on the gear end of the air motor wasn't enough to stop the motor from turning the brush at an acceptable speed and torque.
Apr 30, 2008 | Vacuums
DIrtDevil Ultra Handheld - No Suction & Brush not moving
take everything back out and make sure everything looks fine, then carefully put it back in do not force anything or it will bind up.
Dec 03, 2007 | Dirt Devil M08100RT Classic Handheld...
Vacuums Logo
64 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
